file Frage quadcopter frame prototype
05 Nov 2015 00:09 #26565 von jonalm
quadcopter frame prototype wurde erstellt von jonalm
Using 3mm ply to test before cutting in carbon or G10. had some issues and broke a 1mm endmill then the the work moved on the final cut and messed up the edges. will used double sided tape next time. Arms need a re design.
Had the stepcraft for a couple of weeks now still lots to learn. Big thankyou to Rory for the excellent customer support.
Folgende Benutzer bedankten sich: ThomasDbg, High-Tower, Worldhusky, Mr. B, hoedur, hale2160, Denus
12 Nov 2015 18:42 - 12 Nov 2015 18:44 #26902 von jonalm
jonalm antwortete auf quadcopter frame prototype
Started cutting out in G10material now, everything is 90% done. Will post a vid of some sort of chatter/noisse when cutting the 3.2mm arms, although the stepcraft cut them perfectly.
Letzte Änderung: 12 Nov 2015 18:44 von jonalm.
12 Nov 2015 18:45 #26903 von MrMaJo
MrMaJo antwortete auf quadcopter frame prototype
Nice work !
Gelernt auf Stepcraft 420
  • Detlef01
  • Detlef01s Avatar
  • Besucher
  • Besucher
14 Nov 2015 11:33 #26981 von Detlef01
Detlef01 antwortete auf quadcopter frame prototype
DXF-Datei ?
14 Nov 2015 11:48 - 14 Nov 2015 12:08 #26982 von nio
nio antwortete auf quadcopter frame prototype
Here you have four or five models...
untestedprototype.com/
my machine :P
Stepcraft 840 + CCNC
Kress 1050 and in a near future with SuperPID
Letzte Änderung: 14 Nov 2015 12:08 von nio.
Folgende Benutzer bedankten sich: Detlef01
  • ThomasDbg
  • ThomasDbgs Avatar
  • Offline
  • Moderator
  • Moderator
  • SC2/600 mit HF Spindel 500W
15 Nov 2015 23:48 #27072 von ThomasDbg
ThomasDbg antwortete auf quadcopter frame prototype
Looks good, tell us, how the flight results are after finishing work! Which fc will You use?
Produktevangelist :-)
16 Nov 2015 20:06 #27105 von jonalm
Im going to be using a naze32 FC. AUW as in the image is 173g. I can cut more material out to get the weight down even more.
Folgende Benutzer bedankten sich: ThomasDbg, hoedur
