check Frage milling MDF with vacuum table
02 Okt 2014 11:56 #8717 von Rory
milling MDF with vacuum table wurde erstellt von Rory
S420
hF spindle
1/4 inch shank, 5mm cutting diam
Delrin / Aluminium vacuum table
Standard bagless hoover
the vacuum table pressure is generated using a standard hoover. NOTE if you block off a standard hoover with a table like this its like completely blocking the hoover - if your hoover does not have an underpessure valve or a thermal overload switch this is a very hazardous setup.
We bled the hoover line with the HF extractor - so where the Hoover connects to the vacuum tables outlet we drilled a hole to inser the HF extraction pipe. We therefore get extraction and more than enough under pressure to get great response from the vacuum table.
There is a rubber mat that sits between the top of the vacuum table and the bottom of the work. the next step will be to skim the Ali table surface to get perfect Bed tram on the machine table.
the MDF cut fine with no hopping of work as the parts were cut through. A vacuum tabel is a really impressive addition to the machine. Withouth the need to use clamps - one really opens up the table travel.
02 Okt 2014 11:58 #8718 von Rory
Rory antwortete auf milling MDF with vacuum table
Notice here with the table that not all the holes are covered. The holes in the table start out a approx 6mm and then reduce down to 0.2mm. This allows the table to operate when only partially covered.
We will be making som MDF based tables soon too when we get time.
