file Frage 2D milling of a plywood clock
26 Aug 2014 00:50 - 26 Aug 2014 00:51 #7646 von Rory
2D milling of a plywood clock wurde erstellt von Rory
This video shows 2D milling of a plywood clock
Letzte Änderung: 26 Aug 2014 00:51 von Rory.
07 Sep 2014 12:54 #7950 von heustec
heustec antwortete auf 2D milling of a plywood clock
Rory this clock looks great! is it possible to share the file on here?
07 Sep 2014 15:08 #7954 von Rory
Rory antwortete auf 2D milling of a plywood clock
Yup - we can share the DXF - I'll need to find it first :dry:
11 Sep 2014 12:56 #8053 von creastudiostore
creastudiostore antwortete auf 2D milling of a plywood clock
Hi Rory,
I don't know if it is possible to create a platform were users can share their work files with the community like Youmagine ( www.youmagine.com/ ) or Thingiverse ( www.thingiverse.com/ ) for what concerns 3D printing.
It is just a suggestion.
Best Regards
11 Sep 2014 13:07 #8054 von creastudiostore
Hi Rory,
I forgot to ask you!
I noticed that in the video you use 2 different software. I presume that the first is CUT 2D or 3D and the other is Macth3.
Since I don't have one of this machines I would like to know if the CUT is used to generate the gcode and the Mach3 used to find the "Sweet Spot" (balance between feeds and speeds).If not, can you please explain me the process?
Thank you in advance
Best Regards
11 Sep 2014 22:56 #8071 von Rory
Sorry for late reply here
In relation to the file sharing
yes we will look at sharing platform for users on the file front.
it might make sense to post the files (DXF's and possible the Vcarve/cut2D files) on the post relevant to the video / image. To keep the files specific to the jobs?
What do you think? if you guys as users suggest what is easiest / best to work with we will take suggestions and implement what is best for you guys?
In relation to the Machining
VcarvePro was used in conjunction with Mach3 (we now use UCCNC - see software section).
VcarvePro imports the dxf (or you can design in Vcarve). You the apply the tooling strategy in Vcarve and generate the Gcode file.
MAch3 then controls the machine and interprets the Gcode file. So you can spec feeds in Vcarve - and then tweak the feeds in Mach3. Can you open up a new thread in the "software section" possibly? And ask the question again? So we keep the forum topic specific. We will reply in more detail when you do open up new thread. thanks.
12 Sep 2014 08:25 #8074 von Worldhusky
Worldhusky antwortete auf 2D milling of a plywood clock
Rory schrieb: ... it might make sense to post the files (DXF's and possible the Vcarve/cut2D files) on the post relevant to the video / image. To keep the files specific to the jobs?
Yes - I think that is the only way how it could be convenient for everybody.
It's not only about tools it's also about skills! ;)
  • ThomasDbg
  • ThomasDbgs Avatar
  • Offline
  • Moderator
  • Moderator
  • SC2/600 mit HF Spindel 500W
12 Sep 2014 08:33 #8078 von ThomasDbg
ThomasDbg antwortete auf 2D milling of a plywood clock
Yes, that´s right!
Btw. Rory, looks nice!
Produktevangelist :-)
15 Sep 2014 16:27 #8168 von Rory
We can't find the original file - but here is a DXF'd stopwatch file that you can work with.
If you google "Clock vector" or "stopwatch vector" you will find more examples.
18 Sep 2014 10:01 - 18 Sep 2014 10:03 #8246 von Worldhusky
@Rory
Rory schrieb: We can't find the original file - but here is a DXF'd stopwatch file that you can work with.
It seems to me that this file is empty ....
@heustec
heustec schrieb: Rory this clock looks great! is it possible to share the file on here?
Maybe this will work for you:
Letzte Änderung: 18 Sep 2014 10:03 von Worldhusky.
Folgende Benutzer bedankten sich: Rory
18 Sep 2014 10:53 #8248 von heustec
Thank you very much! This looks great, I might have to try one soon, any thoughts on where to purchase the clock bits?
Alex
18 Sep 2014 15:14 - 18 Sep 2014 15:14 #8252 von Rory
Super - thanks for the file.
IKEA - clocks are like 2£ :) gut the cheapy plastic and use your creation.
the clock in the video was made using a 1mm cutter. BE careful! easily broken!!!
Letzte Änderung: 18 Sep 2014 15:14 von Rory.
Folgende Benutzer bedankten sich: Worldhusky
18 Sep 2014 20:18 #8269 von Worldhusky
Rory schrieb: IKEA - clocks are like 2£ :) gut the cheapy plastic and use your creation.
Smart idea - thanks for the tip! ;)
19 Sep 2014 10:08 #8286 von heustec
Folgende Benutzer bedankten sich: Mr. B
19 Sep 2014 20:36 #8314 von Worldhusky
heustec schrieb: ... 99p each with delivery, will take a while from hong kong mind..!
Yes - that is cheap! But would I be in the market like you for a diy clock movement I would properly spend 0.50 or so more at Amazon to be on a faster and safer side. Delivery time is shorter, customs regulations and return policy is clear and I assume you have not to pay a return postage if you need to return the item.
Just my two cents ....
Amazon.co.uk / Quartz Clock Movement Mechanism
P.s.: And I'm pretty sure it comes anyhow from Hong Kong .... ;)
