file Frage 2D milling in plywood with 1mm cutter
26 Aug 2014 00:48 #7644 von Rory
2D milling in plywood with 1mm cutter wurde erstellt von Rory
This video shows a 1mm cutter being used to mill a biplane out of plywood. The toolpaths were created in VcarvePro and the machine was controlled with Mach3.
Folgende Benutzer bedankten sich: Mr. B
19 Jan 2015 20:38 #14043 von DFence
Hi Rory,
thanks for the great and informative videos.
You could do me a favor and tell me the machine parameters (which bit, how many flutes maybe, feed rate, depth per pass ...).
FOR ME! it looks as if the cutter is flying through the material :woohoo:
Would be very interested. Thanks for your help!
Gruß Toni
19 Jan 2015 22:24 #14055 von frankjoke
frankjoke antwortete auf 2D milling in plywood with 1mm cutter
Looks nice, would like to know as well which depth/speed/tool data :)
I broke yesterday 3x1mm tolls when testing, mainly in corners but I was going with 300mm/min only.
Frank
Absaugung und Vakuumtisch
20 Jan 2015 18:29 - 20 Jan 2015 18:30 #14118 von Rory
2mm and 4mm plywood in these sort of tests.
- 1mm diameter 2 fluted carbide upcutter
- these are very easy to break
- make sure the part is well stuck to the table.
- use spray glue as well as clamping
- any vibration will break cutter
- spindle speed at max
- feed rate at 1000mm/min
- 1 or 2mm per pass
- with cutters you want the cutter as far into the collet with as little cutter sticking out as possible. It helps reduce vibration.
The 1mm tools are tricky and VERY sensitive.
Best use a 2mm if you can.
Hope this helps.
Letzte Änderung: 20 Jan 2015 18:30 von Rory.
Folgende Benutzer bedankten sich: woodendonkey, DFence
