question-circle Frage WinPC NC repetitions and Z-feed correction
10 Mai 2016 21:17 #34069 von darijan
WinPC NC repetitions and Z-feed correction wurde erstellt von darijan
Here is one newbie question. And I mean a total newbie who just assembled his new Stepkraft 840 machine and is making his first project.
It is a question about the settings in WinPC NC (USB version).
Under the setting "Parameters -> Tools" there are options "Depth, Repetitions and Z-Feed correction"
I understand that Depth goes for how deep do I want to go.
Repetitions is how many times will I make one round.
And Z-Feed correction is what puzzles me.
For example, if my material is 8mm thick and I want to cut it through:
1: The Depth will be 8,5mm
Now, if I want to do it in steps of, for example, 2mm, then the Z-Feed correction should be 8,5 / 2 = 2,125?
So, it will go 4 times and each time it will go 2,125mm deeper?
Is that correct?
Thank you for your answers.
13 Mai 2016 21:58 #34130 von Stuart Mellor
Stuart Mellor antwortete auf WinPC NC repetitions and Z-feed correction
Hi
The depth is the initial cut depth - is you set this at 2mm - first cut is 2mm deep.
Z correction - set this at 2mm & subsequent cuts will be an extra 2mm in depth below the first cut.
Repititions is the number of times z correction is repeated.
Notice on your photo you set depth at 8.5mm . Wrong! - if you did that the cutter will immediately plunge to 8.5mm!
Best way - I also struggled with this - make depth, say 2mm & repititions, say 2 & watch the cutter. Use a simple shape, like a small circle or square to experiment with.
