- Dank erhalten: 12
We're talking about aluminum or about aluminum ....finch schrieb: I had my first attempt at Milling aluminium, with disasterous results....
This is not much but it gives you an first idea.finch schrieb: ... are there any tables that actually talk about cut depth.
finch schrieb: I can see a lot of guys using 0.2 to 0.3 mm cut depths on a 3mm bit, which is nothing like the 1/2 diameter Rule of thumb. How are guys coming up with these numbers? - are there any tables that actually talk about cut depth. The Wizard calculator was even telling me 1.5 to 2mm roughing, which also did not work?
Wow! I'm using 6060 aluminum 'cause I was sure it is the easiest to machine...Christian Knüll schrieb: The harder the aluminum the easier to machine. Soft aluminum alloys typically used for anodized profiles are the worst. Aluminum alloys with lead like AlMgCuPb are easy to machine.[/li]
julius schrieb: Are you sure that AlMgCuPb is better?
It would be the one noted as "1060" in wikipedia , I'm right?
Your're right.finch schrieb: Now I'm wondering a little more, the Y axis has the heaviest load on the entire machine by design, cutting along the X axis would be far more Rigid, and then cutting with the indexed 4th axis, more rigid again, probably allowing much faster ( normal ) rates
Material = Aluminium 6060 T6 (not anodized/nicht eloxiert)
Milling bit = 1/8" (3.175mm) Carbide coated 2-Flute End Mill by cnc-plus.de
RPM = 12000
Feed rate = 70 mm/min (1.16 mm/s)
Plunge rate = 50 mm/min (0.83 mm/s)
Deep of Cut = 0.2 mm
Lubrification = 1 or 2 drops of commercial cutting oil every 10 seconds.
