question-circle Frage Laser engraving and WinPC-NC
18 Nov 2017 18:32 #51275 von Alexxfx
Laser engraving and WinPC-NC wurde erstellt von Alexxfx
Hello everybody!
Can anyone explain how it is possible to engrave with laser and WinPC-NC program?
Which kind of software do you use?
Does anybody use Aspire or PhotoVCarve and which way?
Thank you!
Folgende Benutzer bedankten sich: jernejpirc
14 Feb 2018 13:28 - 14 Feb 2018 13:31 #52715 von hugoshelby
hugoshelby antwortete auf Laser engraving and WinPC-NC
I want to recommend interesting article about top of laser engravers 2018 . in this you can found more interesting and iseful for you .I checked it here .
Letzte Änderung: 14 Feb 2018 13:31 von hugoshelby.
24 Dez 2018 14:01 #55493 von Eddie
Eddie antwortete auf Laser engraving and WinPC-NC
Hello Stepcraft users,
The big problem is, the laser ND445 only stays on when it is moved.
I have a Stepcraft 2-420 with a Laser DL445 and software WinPC USB V3. When I run Laser Cut Test under Special functions, the laser DL445 works fine. The laser DL445 turns off if it changes position.
But if I load "muster06" then the laser DL445 stays on, this causes the laser to burn diagonal lines everywhere, this should not be done, the laser DN445 has to go out when the position is moved.
How should the Parameters be set?
Can anyone help?
27 Dez 2018 14:50 #55507 von CNCMiller
CNCMiller antwortete auf Laser engraving and WinPC-NC
Eddie,
It sems like a problem in the G-code (commands missing to turn laser off).
You can try to mail to Burkhard Lewets He is the author of WinPC-NC.
When I had a problem he helped me out with some issues I had with WinPC.
On the other side if it is third party software who creates te code try to contact that manufacturer
good luck
28 Dez 2018 15:03 #55513 von FlyHigh
FlyHigh antwortete auf Laser engraving and WinPC-NC
Hi Alexxfx
might be the movie produced by user UBO helps to understand which config has to be done in your CAM.
In the video ESTLCAM is used. For WinPC-NC the startup delay needs to be G04 Fxxx.
The language is german, but most should be understandable from the video.
Have fun
