exclamation-circle Frage Stepcraft 840 Timing Belt Upgraide!
17 Jan 2018 22:09 - 17 Jan 2018 23:07 #52226 von Hitrijs
Stepcraft 840 Timing Belt Upgraide! wurde erstellt von Hitrijs
Hello from Latvia!
Stepcraft 840 belt is too weak! So I decided to upgrade to 8mm / T5. I no longer have to worry that the strap might break. So I decided to share with others who have encountered this problem.
You can download pulleys T5/10 Tooth STL file ( www.thingiverse.com/thing:2746541 )
Here you can buy a timing belt ( www.beltingonline.com/8t5-1380-synchroflex-belt-8661 )
Letzte Änderung: 17 Jan 2018 23:07 von Hitrijs.
Folgende Benutzer bedankten sich: Doug, Alexxfx
20 Jan 2018 17:18 #52251 von Doug
I have not encountered any difficulties with the drive belt on my machine but thanks for the tip anyway.
Doug
Hobby use: guitar building (luthiery), www.facebook.com/DougShortGuitarBlog/
21 Jan 2018 10:06 #52264 von peterg1000
peterg1000 antwortete auf Stepcraft 840 Timing Belt Upgraide!
I.M.H.O if your machine is destroying timing belts, then there must be excessive loads on them (assuming they have been tensioned correctly) Double check the "tuning" of your Y-axis - with the motor unpowered moving the gantry by pulling on the belt should be relatively easy.
Peter
UC100 + UCCNC
15 Okt 2018 12:10 #54814 von Alexxfx
Alexxfx antwortete auf Stepcraft 840 Timing Belt Upgraide!
Hi!
Is there any analog of pulley from www.beltingonline.com ?
Thnx
07 Jul 2020 09:48 #59264 von Hitrijs
© 2020 STEPCRAFT GmbH & Co. KG
