question-circle Frage looking for pinning internal 26-pole header...
24 Feb 2017 00:18 #44801 von Jodocus
I'm looking for the internal pinning of the Stepcraft. I think I saw a schematic somewhere on the forum, but I'm not able to find it.
Basically what I have found so far is:
1 Spindle on/off OUTPUT
2 DIR X
3 STEP X
4 DIR Y
5 STEP Y
6 DIR Z
7 STEP Z
8 DIR A
9 STEP A
10 Toollength sensor INPUT
11 Emergency stop INPUT
12 HOME X/Y/Z INPUT
13 HOME A INPUY
14 COOLANT OUTPUT
15 ?
16 ?
17 ?
18 GROUND
19 GROUND
20 GROUND
21 GROUND
22 GROUND
23 GROUND
24 GROUND
25 GROUND
26 +5V ?
I hope someone can fill in the gaps and/or confirm the signals please ?
Thanks in advance
  • MagIO2
  • MagIO2s Avatar
  • Offline
  • Forum Nutzer
  • Forum Nutzer
24 Feb 2017 06:41 #44804 von MagIO2
Guess your labels are from PC point of view and not from SC header point of view, otherwise I and O are swapped.
SC Machine parameters
24 Feb 2017 11:37 #44819 von Jodocus
Uhh, I think your right :P
I'll will double check, but do you perhaps know whether the signals are correct and/or what the missing signals are ?
24 Feb 2017 12:37 #44822 von Rahul
Jodocus schrieb: Hi,
Pin 17 (PWM) is used by the HF-Spindle to control the rpm (in my opinion).
You should look for the Arduino Shield in this forum there could be more information.
25 Feb 2017 00:07 #44873 von Jodocus
Thanks, I'll look. I'm sure I saw somewhere in a thread more info... Should have marked it :S
  • MagIO2
  • MagIO2s Avatar
  • Offline
  • Forum Nutzer
  • Forum Nutzer
25 Feb 2017 00:32 - 25 Feb 2017 00:36 #44874 von MagIO2
You understand that the words written in orange are a link to a PDF listing the Pinout on page 2, first table?
Letzte Änderung: 25 Feb 2017 00:36 von MagIO2.
Folgende Benutzer bedankten sich: Jodocus
