- Dank erhalten: 131
I would skip the starter option and get the machine with parallel port if your plan is Mach3 and XP anyway. Mach3 is free to use in demo mode and 500 g-code limit should help you get familiar with the machine before buying the full version. Laptop probably needs some fine tuning unless you use an external controller like UC100.peterg1000 schrieb: Hi,
Once I have some familiarity with the machine I want to use MACH3 on a laptop with a parallel port and running Windows XP. Does this mean that I have to remove the converter board if it is a separate item, or does the Stepcraft accept either USB or parallel data as delivered in the starter kit.
