The M700 is assembled. But I am running into a host of problems, and feel I am missing a whole manual somewhere to explain things!
1. At first the machine wouldnt initialize, and I saw on the signal test there were several "lights" out correlating to pin 11, then after restarting WINPCNC it showed 11 on and 10 off etc. I figured out these related to stop switches, so eventually after wiggling them to ensure the switches were not engaged, it just magically work...
2. I "initialized" machine, and it started moving in Z+ and kept going into the bed until it started pushing the spindle out of the holder - I hit the emergency stop.
3. I started testing the axes, and I can jog the machine with the WINPCNC software but not the pendant. BUT the most stop switches do nothing (manually press them)! Only one of the switches on the Y axis stops the machine moving. The other side does nothing, and neither top or bottom Z axis stop switch has any effect! The machine could just run right into the frame if I let it. Are the switches meant to be IN or OUT position normally? The assembly instructions are unclear because they say to bend until you hear a "click" which indicates that they should be IN all the time and are released if reaching a physical end... The switches are well wired and have current.
4. In manual "First Steps WINPC-NC" step 2.5 describes levelling the machin and then following steps 5.2 and 5.4.. Where are these steps??? They are not in assembly or any other manual... This whole section is quite unclear to me.
5. Lastly, if we have to take off the main gantry uprights (parts 3 and 4), then we are really "screwed" - as the small bolts stripped immediately even on the lightest torque setting and cannot be loosened now >
Regards,
Brian
