file Frage hf spindle controler dos not work
18 Apr 2017 03:39 #46442 von m.creative
hf spindle controler dos not work wurde erstellt von m.creative
Hello:
For first ran hf spindle controler dos not work at all .
and I have Stepcraft 600 “Elite” . please help to Solving the problem .
  • MagIO2
  • MagIO2s Avatar
  • Offline
  • Forum Nutzer
  • Forum Nutzer
18 Apr 2017 07:53 #46444 von MagIO2
MagIO2 antwortete auf hf spindle controler dos not work
As the LED is off, it looks like you have a problem with the power supply.
And as you ask for help in such a general way, I would give the advice to contact Stepcraft, just as mentioned in the troubleshooting section of the manual. Working with main power supply is a no-go for people not educated in this matter.
I am not sure if I understand the manual correctly, so the only thing you might double-check before is, wheather the emergency stop button works correctly. In the German manual it says, that the emergency stop button switches off the control unit, leaving lots of room for doubts and misunderstanding ... and as I don't ow an SC spindle so far, I can't check.
So, does the machine move?
17 Mai 2017 17:58 - 17 Mai 2017 18:00 #47306 von orenhag
orenhag antwortete auf hf spindle controler dos not work
MaglO2
No need to blame ppl for posting their problems in the forum.
Welcome to the English DIY world - We live and breath forums. We try to fix stuff our selves.
Thank you.
Letzte Änderung: 17 Mai 2017 18:00 von orenhag.
17 Mai 2017 20:10 #47315 von DerRoy
DerRoy antwortete auf hf spindle controler dos not work
@orenhag
Why do you believe Andreas ist blaming anyone?
Instead of you, he ist at least trying to give some help, your Post is totaly useless.
@m.creative
Pls. Check with disconnected spindle if the machine is moving and double check the emergency button.
If it moves without the spindle connected you have a problem with the spindle controller. If so, pls. get in contact to Stepcraft or your reseller and claim warranty.
MfG
Roy
