Adapter for HXKJ-GS52-400W Spindle
Adapter for
HXKJ-GS52-400W
Air cooled DC spindle
Voltage DC48V
Speed 12000RPM
Material: Aluminium
M4x40 Socket head cap screws stainless steel (x3)
Stepcraft 420 (version 1) - HXKJ-GS52-400W Air cooled DC spindle - 445nm Blue Laser diode G2
Please see PDF file with dimensions attached below
Looks great, pretty tight fit 😛 . How about the noise? Is the low RPM a problem (compared to the 20.000 of the proxxon)?
It is a bit of a squeeze to get in but could always make a replacement extended tool holder to remedy that.
I've run it 3/4 to max and it's very quite compared to the proxxon.
For the moment cutting oak it's been great.
Also the driver that comes with it has an out put to connect to PWM on mach3. (I've not done this yet though).
For £115 and the ability to hold up to a 7mm cutter I thought I'd give it a go. So far very happy.
Hey blanthegenius,
one more question: whats the weight of the system (motor + adapter)?
I was watching a auction at eBay but it seems this professional grade motor (max. rmp 30.000) might be worth a consideration.
Hello Speedo,
The weight of the motor plus adapter is:
1.1 Kg or 2.42 lbs
That looks like a belter,
If you do get this one let me know how you get on with it please.
- 7,336 Themen
