cannot run spindle but can move axis from uccnc
I've built the M700 successfully, managed to control axis rotors.
BUT - I failed to run the spindle.
tried the command "S12000 M3" and some other options.
Tried to run the logo examples - machine moves but spindle is off.
I'm using a spindle AMB FME-P Di.
Please help.
the most common error is the switch on the spindle itself. It's a latched switch which can switch back to off on itself easily.
The other problem might be the configuration. Please check in "diagnostics" that pwm is flashing and relais 1 is on when the spindle is set to run (either via button or M3)
Since there was a similar problem not long ago - maybe contact stepcraft support if this doesn't help
Autodesk Fusion 360 CAD / CAM Operator / Designer
Autodesk Eagle / KiCAD Elektronikentwickler
Stepcraft M.700 (UCCNC)
- 7,667 Themen
