Winpc nc economy
Hi to all the forum, maybe someone have the file with the parameters from the machine stepcraft 600 to load it in the winpc nc , thanks.
Hi jeyb,
here you are! These are the 2 sc600 files I could find in the starter version of WinPC NC.
Thanks MagIO2 for the quick reply!!
ok the parameters works its all corect, but i need and the parameters from singnals because i have the lpt1 version of stepcraft 600 and i dont understand how to fill the parameters in the winpc nc.the parameters is hear https://www.stepcraft-systems.com/images/Service/connection-diagramm-v1.pdf
Hi Jerb
this is the Default Setting in WinPCNC Economic
5.1.1. Pin assignment of clock/direction version:
Pinning LPT 1
(clock/direction)
All signals on the LPT printer ports present 5V TTL level.
Pinning of the first LPT port is as follows:
Pin 2 output direction motor X
Pin 3 output clock motor X
Pin 4 output direction motor Y
Pin 5 output clock motor Y
Pin 6 output direction motor Z
Pin 7 output clock motor Z
Pin 8 output direction motor 4 (i.g.tangential axis)
Pin 9 output clock motor 4 (i.g. tangential axis)
Pin 1 output drilling spindle on/off (default)
Pin 14 output coolant pump on/off (default)
Pin 16 output current reduction (default)
Pin 17 output job works (default)
Pin 10 input reference switch X (default)
Pin 11 input reference switch Y (default)
Pin 12 input reference switch Z (default)
Pin 13 input sensor/surface block (default)
Pin 15 input vacant
Pin 18-25 signal mass (0V GND)
You have to Change following Settings:
Pin10 Input from Reference Switch x to tool length sensor
Pin11 input reference switch Y to emergency stop
Pin12 input reference switch Z (Default) to Input reference Switch x, y and z
This should be all you need to change.
Please have a look at WinPCNC Handbook, Page 83.
Kind regards Christian
Thanks vhoren
please to tell me someone how to create a 3d file to winpcnc-economy and create a reilef picture.PLEASE HELP I NEED THIS INFORMATION IF SOMEONE KNOW TO TELL ME QUICKLY 🙁
- 12 Online
