Parameters
Can anyone upload a parameterfile for winpc-nc usb
im new to this and would be glad to get an correct file
if its possible to do it like that ?
In my software i can load an parameter file
/Jörgen
Jorgen,
we don't have the WinPC files - as we use UCCNC and used to use Mach3.
If no-one posts here soon - I'll get STEPCRAFT to post the parameters up here.
Thanks
Rory
![Peter Urban Peter Urban](http://stepcraft-systems.com/wp-content/uploads/wpforo/avatars/_PU__26116.gif)
Hello,
here you can find a tool to setup the standard parameter for WinPC-NC Starter and WinPC-NC USB fullversion
https://www.stepcraft-systems.com/images/Service/Softwareupdater.pdf
Peter Urban
Thanx ver much and i like fast answers !!!
Think i got it right 🙂
/Jörgen
If i buy the uccnc to i really need the uc100 adapter
it looks like it converts from usb to pararell !
do i need an pararellmodule also
i now have Stepcraft USB module in it and there is also an other port
but it is not as wide as the old pararell ports
Happy for an explanation
/Jörgen
that second slot is for the 4th axis-module i guess.
do i need an pararellmodule alsoi now have Stepcraft USB module in it and there is also an other port
but it is not as wide as the old pararell portsHappy for an explanation
/Jörgen
The UC100 is a full CNC controller that works on USB. This is much more than USB - parallel module. The output on the machine side is an LPT for compatibility. So you need to remove the WinPC card - and install the parallel adaptor card. Then the UC100 can control the STEPCRAFT machine.
The second slot has outputs for the 4th axis module controls. Like the 3D printer. You cannot connect the Uc100 here.
if you get the UC100 and UCCNC you need the setup files - or you have to configure all the settings from the manual. Please email us if you need the settings.
- 7,662 Themen
