OTK Tangential A-axis configuration on UCCNC
![Manu FernandesVillela Manu FernandesVillela](http://stepcraft-systems.com/wp-content/uploads/wpforo/avatars/manufv@pt.lu_40750.png)
hi everybody.
I've a question how to configure the 'homing' sequence to have the a axis / tangential knife correctly parallel with x-axis.
when I perform homing, the a-axis turn at 11h (o'clock representation)
but UCCNC show a 3h (o'clock representation) which is the desired effect to be parallel to x-axis
I want to configure uccnc ? macro ? offsets ? to turn the a-axis +220 and then have the good a-axis orientation
is anyone have any idea how to do it ?
with kind regards.
manufv
hi all,
for share, I finally setup the OTK and good blade orientation.
I use UCCNC 1.211x and I must define the screenset to default because the stepcraft's one is out-of-date.
How to use stepcraft machine profiles with default screenset ?
edit ..UCCNCProfilesStepcraft2_Model840.pro with notpad.exe
set the mainscreenfilename=Defaultscreenset (2sd line)
save and start uccnc with the stepcraft profile.
Configuration/Aaxis with Tangentials options.
I setup the back-off to put the blade paralel to Xaxis, ready to cut.
Configuration/Spindle
manufv
ps : a release 1.2113 is on the way, some bug solved.
manufv
- 10 Online
