winpc-nc guides and tutorials?
New user here. Just got and setup the Stepcraft 840. It came with the winpc-nc software and have run through the software a few times and managed to get some plotting done with a pen to test out the machine.
I am having issues figuring out the work piece area. I am bringing in the work files from Vcarve pro with all the required settings but it is not reflecting in winpc-nc.
I am thinking of changing to UCCNC and wondering how i would go about doing that?
any help would be much appreciated.
cheers
hassa
Hi Hassa,
If you are going to change to UCCNC, then you will need to purchase a UC100 motion controller and a parallel interface card. The UC100 license allows the UCCNC to communicate with the motion controller via a standard USB cable. The parallel interface card replaces the USB card currently plugged into your Stepcraft control board.
The latest version of UCCNC can always be downloaded from the CNCdrive website and possibly from the Stepcraft site as well. You wont regret the change, UCCNC is very powerful and easy to learn, and the motion controller relieves the control computer of all time critical operations so a very low specification PC is adaquate. I personally use Windows XP on an old "pre-used" Dell.
You will also need to obtain a profile file suitable for your SC2/840 machine - again Stepcraft or your local agent should be able to supply you with this f.o.c
Peter
UC100 + UCCNC
Hello,
I think it's not because WinPcNc but the settings
another software would not solve the problem
Greeting Fritz
Hey guys,
Thanks for the replies.
F7222:
you are right about the software settings. I just think that UCCNC has a better interface and lots more guides/tutorials available.
I could definitely use winpc-nc in the meantime for practice.
Peterg1000:
That's great news. Is swapping out the usb card for a parallel card a very tricky job? Im worried about messing around with the controller board.
Thanks
Anyone got any good links to tutorials or guides in English for winpc-nc?
Hi Hassa,
Replacement of the USB board with the parallel board is simply a matter of unplugging one and replacing with the other. You will also need to change the cover (item 67) - I think that will have to be ordered as a separate item to the parallel board, not sure though.
Regards,
Peter
UC100 + UCCNC
Hassa,
WinPC-Nc is as good as UCCNC it all depends on what you expect to get.
WinPC that comes with the machine is the light version and that one is just to get you started and make a your first 2D project.
If you want to use this program uprade it to the USB full version (now version 3 is available) at http://www.lewetz.de/de/sample-sites-2/winpc-nc/fuer-stepcraft-maschinen
Here you also can find the English manual for version 3 at http://www.lewetz.de/de/service/downloads
In this new version you can see the actual real time position of your mill bit when the job is being carried out and the 3D model as well.
So think of what you want, I like this WinPC-NC v.3
PS. I create my G-Code in the Vecric programs with the post processor WinPC-NC Arcs mm (*.nc) and this works fine.
good luck
- 16 Online
