Automatic tool change. fusion 360
Hello
How do I stop the Machine from doing a automatic tool change without have to edit the G-code . I don't have a automatic tool change
Where do I turn this feature off in fusion 360
Thanks
Thank you for that
Hello
I had a look on my post process where it says ( use tool changer no ) but the Y axis always goes down to the bottom right corner and the X axis goes all the way to the right and Z goes all the way to the top Walt 3 second and then come back and start to mill
Thanks
![Per Takman Per Takman](http://stepcraft-systems.com/wp-content/uploads/wpforo/avatars/per.takman_32782.png)
Check the settings in UCCNC configuration as well. There is an option for how UCCNC should handle tool changes. Another thing to consider if you're posting several strategies into one NC-file which all use the same tool is to make sure that you've sorted out the tool numbering in Fusion.
Good luck!
/Per
- 22 Online
