Machine not returning to zero if Y axis reaches 0
Hello,
Among many problems I'm having with this machine, the machine is not returning to zero if the machine reaches the minimum travel of the y axis. Why is this? The post process of Fusion360 is sending it to the tool change position, min y/ min x...it makes thud as it comes to a stop and turns the spindle on the returns to a spot about 3/4" north of zero. I did some manual jogs an ran to machine to its limits then pressed GOTO ZERO, it will return to the zero point as long as it didn't encounter the min y limit (physical limit) What's going on?
Here's my G-code of the part I'm trying to produce
(G5 FLUSH)
(T1 D=3.175 CR=0. - ZMIN=-2.27 - flat end mill)
G90 G64
G0 G53 Z0.
(Bore2)
(Move to tool change position)
G53 X0. Y0.
T1 M6 (flat end mill D=3.175 1/8" Flat Endmill)
S13000 M3
G54
G43 H1
G0 X31.4 Y31.241
Z15.
Z0.683
G1 Z-1. F300
X31.559
G3 X31.718 Y31.4 I0. J0.159
X31.082 Z-1.5 I-0.318 J0. F700
X31.718 Z-2. I0.318 J0.
X31.36 Y31.715 Z-2.27 I-0.318 J0.
X31.44 Y31.085 I0.04 J-0.315
X31.36 Y31.715 I-0.04 J0.315
X31.223 Y31.538 I0.02 J-0.157 F609.6
G1 X31.243 Y31.38
G0 Z5.
X0. Y45.541
Z0.683
G1 Z-1. F300
X0.159
G3 X0.317 Y45.7 I0. J0.159
X-0.317 Z-1.5 I-0.317 J0. F700
X0.317 Z-2. I0.317 J0.
X-0.04 Y46.015 Z-2.27 I-0.317 J0.
X0.04 Y45.385 I0.04 J-0.315
X-0.04 Y46.015 I-0.04 J0.315
X-0.177 Y45.838 I0.02 J-0.157 F609.6
G1 X-0.157 Y45.68
G0 Z5.
X-31.4 Y31.241
Z0.683
G1 Z-1. F300
X-31.241
G3 X-31.083 Y31.4 I0. J0.159
X-31.717 Z-1.5 I-0.317 J0. F700
X-31.082 Z-2. I0.317 J0.
X-31.44 Y31.715 Z-2.27 I-0.318 J0.
X-31.36 Y31.085 I0.04 J-0.315
X-31.44 Y31.715 I-0.04 J0.315
X-31.577 Y31.538 I0.02 J-0.157 F609.6
G1 X-31.557 Y31.38
G0 Z5.
X-31.4 Y-31.559
Z0.683
G1 Z-1. F300
X-31.241
G3 X-31.083 Y-31.4 I0. J0.159
X-31.44 Y-31.085 Z-2.27 I-0.318 J0.
X-31.36 Y-31.715 I0.04 J-0.315
X-31.44 Y-31.085 I-0.04 J0.315
X-31.577 Y-31.262 I0.02 J-0.157 F609.6
G1 X-31.557 Y-31.42
G0 Z15.
(2D Contour5)
X-26.968 Y-32.991
Z15.
Z5.
G1 Z2.818 F300
X-26.963 Y-32.985 Z2.747
X-26.948 Y-32.967 Z2.68
X-26.924 Y-32.938 Z2.62
X-26.892 Y-32.899 Z2.569
X-26.853 Y-32.853 Z2.531
X-26.811 Y-32.801 Z2.508
X-26.765 Y-32.747 Z2.5
X-26.563 Y-32.503
G3 X-26.604 Y-32.056 I-0.244 J0.203
G2 X-41.658 Y0. Z1.223 I26.604 J32.056 F609.6
X-28.71 Y30.185 Z0.044 I41.658 J0.
X-15.707 Y38.583 Z-0.5 I28.709 J-30.185
X0. Y41.658 I15.706 J-38.583 F700
Y-41.658 I0. J-41.658
X-41.658 Y0. I0. J41.658
X-28.71 Y30.185 I41.658 J0.
X-15.707 Y38.583 I28.709 J-30.185
G0 Z5.
X-43.146 Y45.793
G1 Z2.817 F300
X-43.149 Y45.8 Z2.748 F609.6
G3 X-43.156 Y45.821 Z2.682 I-0.301 J-0.1
X-43.172 Y45.853 Z2.623 I-0.294 J-0.121
X-43.199 Y45.894 Z2.573 I-0.278 J-0.153
X-43.238 Y45.936 Z2.535 I-0.251 J-0.194
X-43.29 Y45.974 Z2.51 I-0.212 J-0.236
X-43.353 Y46.002 Z2.5 I-0.16 J-0.274
X-43.45 Y46.018 Z2.497 I-0.097 J-0.302
G2 X-43.809 Y46.059 Z2.484 I0. J1.587
X-43.768 Y45.7 Z2.471 I-1.546 J-0.359
G3 X-43.132 Z2.436 I0.318 J0.
X-43.45 Y46.018 Z2.419 I-0.318 J0.
G2 X-43.809 Y46.059 Z2.406 I0. J1.587
X-43.768 Y45.7 Z2.394 I-1.546 J-0.359
G3 X-43.132 Z2.359 I0.318 J0.
X-43.45 Y46.018 Z2.342 I-0.318 J0.
G2 X-43.809 Y46.059 Z2.329 I0. J1.587
X-43.768 Y45.7 Z2.316 I-1.546 J-0.359
G3 X-43.132 Z2.281 I0.318 J0.
X-43.45 Y46.018 Z2.264 I-0.318 J0.
G2 X-43.809 Y46.059 Z2.251 I0. J1.587
X-43.768 Y45.7 Z2.239 I-1.546 J-0.359
G3 X-43.132 Z2.204 I0.318 J0.
X-43.45 Y46.018 Z2.187 I-0.318 J0.
G2 X-43.809 Y46.059 Z2.174 I0. J1.587
X-43.768 Y45.7 Z2.161 I-1.546 J-0.359
G3 X-43.132 Z2.126 I0.318 J0.
X-43.45 Y46.018 Z2.109 I-0.318 J0.
G2 X-43.809 Y46.059 Z2.096 I0. J1.587
X-43.768 Y45.7 Z2.084 I-1.546 J-0.359
G3 X-43.132 Z2.049 I0.318 J0.
X-43.45 Y46.018 Z2.032 I-0.318 J0.
G2 X-43.809 Y46.059 Z2.019 I0. J1.587
X-43.768 Y45.7 Z2.006 I-1.546 J-0.359
G3 X-43.132 Z1.971 I0.318 J0.
X-43.45 Y46.018 Z1.954 I-0.318 J0.
G2 X-43.809 Y46.059 Z1.941 I0. J1.587
X-43.768 Y45.7 Z1.929 I-1.546 J-0.359
G3 X-43.132 Z1.894 I0.318 J0.
X-43.45 Y46.018 Z1.877 I-0.318 J0.
G2 X-43.809 Y46.059 Z1.864 I0. J1.587
X-43.768 Y45.7 Z1.851 I-1.546 J-0.359
G3 X-43.132 Z1.816 I0.318 J0.
X-43.45 Y46.018 Z1.799 I-0.318 J0.
G2 X-43.809 Y46.059 Z1.786 I0. J1.587
X-43.768 Y45.7 Z1.774 I-1.546 J-0.359
G3 X-43.132 Z1.739 I0.318 J0.
X-43.45 Y46.018 Z1.722 I-0.318 J0.
G2 X-43.809 Y46.059 Z1.709 I0. J1.587
X-43.768 Y45.7 Z1.696 I-1.546 J-0.359
G3 X-43.132 Z1.661 I0.318 J0.
X-43.45 Y46.018 Z1.644 I-0.318 J0.
G2 X-43.809 Y46.059 Z1.631 I0. J1.587
X-43.768 Y45.7 Z1.619 I-1.546 J-0.359
G3 X-43.132 Z1.584 I0.318 J0.
X-43.45 Y46.018 Z1.567 I-0.318 J0.
G2 X-43.809 Y46.059 Z1.554 I0. J1.587
X-43.768 Y45.7 Z1.541 I-1.546 J-0.359
G3 X-43.132 Z1.506 I0.318 J0.
X-43.45 Y46.018 Z1.489 I-0.318 J0.
G2 X-43.809 Y46.059 Z1.476 I0. J1.587
X-43.768 Y45.7 Z1.464 I-1.546 J-0.359
G3 X-43.132 Z1.429 I0.318 J0.
X-43.45 Y46.018 Z1.411 I-0.318 J0.
G2 X-43.809 Y46.059 Z1.399 I0. J1.587
X-43.768 Y45.7 Z1.386 I-1.546 J-0.359
G3 X-43.132 Z1.351 I0.318 J0.
X-43.45 Y46.018 Z1.334 I-0.318 J0.
G2 X-43.809 Y46.059 Z1.321 I0. J1.587
X-43.768 Y45.7 Z1.309 I-1.546 J-0.359
G3 X-43.132 Z1.274 I0.318 J0.
X-43.45 Y46.018 Z1.256 I-0.318 J0.
G2 X-43.809 Y46.059 Z1.244 I0. J1.587
X-43.768 Y45.7 Z1.231 I-1.546 J-0.359
G3 X-43.132 Z1.196 I0.318 J0.
X-43.45 Y46.018 Z1.179 I-0.318 J0.
G2 X-43.809 Y46.059 Z1.166 I0. J1.587
X-43.768 Y45.7 Z1.154 I-1.546 J-0.359
G3 X-43.132 Z1.119 I0.318 J0.
X-43.45 Y46.018 Z1.101 I-0.318 J0.
G2 X-43.809 Y46.059 Z1.089 I0. J1.587
X-43.768 Y45.7 Z1.076 I-1.546 J-0.359
G3 X-43.132 Z1.041 I0.318 J0.
X-43.45 Y46.018 Z1.024 I-0.318 J0.
G2 X-43.809 Y46.059 Z1.011 I0. J1.587
X-43.768 Y45.7 Z0.999 I-1.546 J-0.359
G3 X-43.132 Z0.964 I0.318 J0.
X-43.45 Y46.018 Z0.946 I-0.318 J0.
G2 X-43.809 Y46.059 Z0.934 I0. J1.587
X-43.768 Y45.7 Z0.921 I-1.546 J-0.359
G3 X-43.132 Z0.886 I0.318 J0.
X-43.45 Y46.018 Z0.869 I-0.318 J0.
G2 X-43.809 Y46.059 Z0.856 I0. J1.587
X-43.768 Y45.7 Z0.844 I-1.546 J-0.359
G3 X-43.132 Z0.809 I0.318 J0.
X-43.45 Y46.018 Z0.791 I-0.318 J0.
G2 X-43.809 Y46.059 Z0.779 I0. J1.587
X-43.768 Y45.7 Z0.766 I-1.546 J-0.359
G3 X-43.132 Z0.731 I0.318 J0.
X-43.45 Y46.018 Z0.714 I-0.318 J0.
G2 X-43.809 Y46.059 Z0.701 I0. J1.587
X-43.768 Y45.7 Z0.689 I-1.546 J-0.359
G3 X-43.132 Z0.654 I0.318 J0.
X-43.45 Y46.018 Z0.636 I-0.318 J0.
G2 X-43.809 Y46.059 Z0.624 I0. J1.587
X-43.768 Y45.7 Z0.611 I-1.546 J-0.359
G3 X-43.132 Z0.576 I0.318 J0.
X-43.45 Y46.018 Z0.559 I-0.318 J0.
G2 X-43.809 Y46.059 Z0.546 I0. J1.587
X-43.768 Y45.7 Z0.534 I-1.546 J-0.359
G3 X-43.132 Z0.499 I0.318 J0.
X-43.45 Y46.018 Z0.481 I-0.318 J0.
G2 X-43.809 Y46.059 Z0.469 I0. J1.587
X-43.768 Y45.7 Z0.456 I-1.546 J-0.359
G3 X-43.132 Z0.421 I0.318 J0.
X-43.45 Y46.018 Z0.404 I-0.318 J0.
G2 X-43.809 Y46.059 Z0.391 I0. J1.587
X-43.768 Y45.7 Z0.379 I-1.546 J-0.359
G3 X-43.132 Z0.344 I0.318 J0.
X-43.45 Y46.018 Z0.326 I-0.318 J0.
G2 X-43.809 Y46.059 Z0.314 I0. J1.587
X-43.768 Y45.7 Z0.301 I-1.546 J-0.359
G3 X-43.132 Z0.266 I0.318 J0.
X-43.45 Y46.018 Z0.249 I-0.318 J0.
G2 X-43.809 Y46.059 Z0.236 I0. J1.587
X-43.768 Y45.7 Z0.224 I-1.546 J-0.359
G3 X-43.132 Z0.189 I0.318 J0.
X-43.45 Y46.018 Z0.171 I-0.318 J0.
G2 X-43.809 Y46.059 Z0.159 I0. J1.587
X-43.768 Y45.7 Z0.146 I-1.546 J-0.359
G3 X-43.132 Z0.111 I0.318 J0.
X-43.45 Y46.018 Z0.094 I-0.318 J0.
G2 X-43.809 Y46.059 Z0.081 I0. J1.587
X-43.768 Y45.7 Z0.069 I-1.546 J-0.359
G3 X-43.132 Z0.034 I0.318 J0.
X-43.45 Y46.018 Z0.016 I-0.318 J0.
G2 X-43.809 Y46.059 Z0.004 I0. J1.587
X-43.768 Y45.7 Z-0.009 I-1.546 J-0.359
G3 X-43.132 Z-0.044 I0.318 J0.
X-43.45 Y46.018 Z-0.061 I-0.318 J0.
G2 X-43.809 Y46.059 Z-0.074 I0. J1.587
X-43.768 Y45.7 Z-0.086 I-1.546 J-0.359
G3 X-43.132 Z-0.121 I0.318 J0.
X-43.45 Y46.018 Z-0.139 I-0.318 J0.
G2 X-43.809 Y46.059 Z-0.151 I0. J1.587
X-43.768 Y45.7 Z-0.164 I-1.546 J-0.359
G3 X-43.132 Z-0.199 I0.318 J0.
X-43.45 Y46.018 Z-0.216 I-0.318 J0.
G2 X-43.809 Y46.059 Z-0.229 I0. J1.587
X-43.768 Y45.7 Z-0.241 I-1.546 J-0.359
G3 X-43.132 Z-0.276 I0.318 J0.
X-43.45 Y46.018 Z-0.294 I-0.318 J0.
G2 X-43.809 Y46.059 Z-0.306 I0. J1.587
X-43.768 Y45.7 Z-0.319 I-1.546 J-0.359
G3 X-43.132 Z-0.354 I0.318 J0.
X-43.45 Y46.018 Z-0.371 I-0.318 J0.
G2 X-43.809 Y46.059 Z-0.384 I0. J1.587
X-43.768 Y45.7 Z-0.396 I-1.546 J-0.359
G3 X-43.132 Z-0.431 I0.318 J0.
X-43.45 Y46.018 Z-0.449 I-0.318 J0.
G2 X-43.809 Y46.059 Z-0.461 I0. J1.587
X-43.768 Y45.7 Z-0.474 I-1.546 J-0.359
G3 X-43.225 Y45.475 Z-0.5 I0.318 J0.
X-43.45 Y46.018 I-0.225 J0.225 F700
G2 X-43.809 Y46.059 I0. J1.587
X-43.768 Y45.7 I-1.546 J-0.359
G3 X-43.225 Y45.475 I0.318 J0.
G0 Z5.
X-45.99 Y-54.445
G1 Z2.818 F300
X-45.982 Z2.747
X-45.959 Z2.68
X-45.921 Z2.62
X-45.87 Z2.569
X-45.81 Z2.531
X-45.743 Z2.508
X-45.673 Z2.5
X-45.355
G3 X-45.037 Y-54.127 I0. J0.317
G1 Y-47.605 Z2.272 F609.6
G2 X-44.996 Y-47.246 Z2.26 I1.587 J0.
X-45.355 Y-47.287 Z2.247 I-0.359 J1.546
G1 X-59.045 Z1.769
G2 X-60.632 Y-45.7 Z1.682 I0. J1.587
G3 X-61.268 Z1.647 I-0.318 J0.
G2 X-62.855 Y-47.287 Z1.56 I-1.587 J0.
G1 X-73.65 Z1.183
G2 X-75.238 Y-45.7 Z1.096 I0. J1.587
G1 Y0. Z-0.5
Y45.7 F700
G2 X-73.65 Y47.287 I1.588 J0.
G1 X-62.855
G2 X-61.268 Y45.7 I0. J-1.587
G3 X-60.632 I0.318 J0.
G2 X-59.045 Y47.287 I1.588 J0.
G1 X-45.355
G2 X-44.996 Y47.246 I0. J-1.587
X-45.037 Y47.605 I1.546 J0.359
G1 Y61.295
G2 X-43.45 Y62.882 I1.587 J0.
G3 Y63.518 I0. J0.318
G2 X-45.037 Y65.105 I0. J1.588
G1 Y75.9
G2 X-43.45 Y77.488 I1.587 J0.
G1 X43.45
G2 X45.037 Y75.9 I0. J-1.588
G1 Y65.105
G2 X43.45 Y63.518 I-1.587 J0.
G3 Y62.882 I0. J-0.318
G2 X45.037 Y61.295 I0. J-1.588
G1 Y47.605
G2 X44.996 Y47.246 I-1.587 J0.
X45.355 Y47.287 I0.359 J-1.546
G1 X59.045
G2 X60.632 Y45.7 I0. J-1.587
G3 X61.268 I0.318 J0.
G2 X62.855 Y47.287 I1.587 J0.
G1 X73.65
G2 X75.238 Y45.7 I0. J-1.587
G1 Y-45.7
G2 X73.65 Y-47.287 I-1.588 J0.
G1 X62.855
G2 X61.268 Y-45.7 I0. J1.587
G3 X60.632 I-0.318 J0.
G2 X59.045 Y-47.287 I-1.588 J0.
G1 X45.355
G2 X44.996 Y-47.246 I0. J1.587
X45.037 Y-47.605 I-1.546 J-0.359
G1 Y-61.295
G2 X43.45 Y-62.882 I-1.587 J0.
G3 Y-63.518 I0. J-0.318
G2 X45.037 Y-65.105 I0. J-1.588
G1 Y-75.9
G2 X43.45 Y-77.488 I-1.587 J0.
G1 X-43.45
G2 X-45.037 Y-75.9 I0. J1.588
G1 Y-65.104
G2 X-43.398 Y-63.517 I1.587 J0.
G3 X-43.071 Y-63.2 I0.01 J0.317
X-43.398 Y-62.883 I-0.318 J0.
G2 X-45.037 Y-61.296 I-0.052 J1.587
G1 Y-47.605
G2 X-44.996 Y-47.246 I1.587 J0.
X-45.355 Y-47.287 I-0.359 J1.546
G1 X-59.045
G2 X-60.632 Y-45.7 I0. J1.587
G3 X-61.268 I-0.318 J0.
G2 X-62.855 Y-47.287 I-1.587 J0.
G1 X-73.65
G2 X-75.238 Y-45.7 I0. J1.587
G1 Y0.
Y24.54 Z-1. F609.6
Y45.7 F700
G1 X-62.855
G1 X-45.355
G1 Y61.295
G1 Y75.9
G1 X43.45
G1 Y65.105
G1 Y47.605
G1 X59.045
G1 X73.65
G1 Y-45.7
G1 X62.855
G1 X45.355
G1 Y-61.295
G1 Y-75.9
G1 X-43.45
G1 Y-65.104
G1 Y-47.605
G1 X-59.045
G1 X-73.65
G1 Y0.
Y24.54
G0 Z5.
X-26.968 Y-32.991
G1 Z2.318 F300
X-26.963 Y-32.985 Z2.247
X-26.948 Y-32.967 Z2.18
X-26.924 Y-32.938 Z2.12
X-26.892 Y-32.899 Z2.069
X-26.853 Y-32.853 Z2.031
X-26.811 Y-32.801 Z2.008
X-26.563 Y-32.503
G2 X-41.658 Y0. Z0.723 I26.604 J32.056 F609.6
X-28.71 Y30.185 Z-0.456 I41.658 J0.
X-15.707 Y38.583 Z-1. I28.709 J-30.185
G0 Z5.
X-43.146 Y45.793
G1 Z2.317 F300
X-43.149 Y45.8 Z2.248 F609.6
G3 X-43.156 Y45.821 Z2.182 I-0.301 J-0.1
X-43.172 Y45.853 Z2.123 I-0.294 J-0.121
X-43.199 Y45.894 Z2.073 I-0.278 J-0.153
X-43.238 Y45.936 Z2.035 I-0.251 J-0.194
X-43.29 Y45.974 Z2.01 I-0.212 J-0.236
X-43.353 Y46.002 Z2. I-0.16 J-0.274
X-43.45 Y46.018 Z1.997 I-0.097 J-0.302
G2 X-43.809 Y46.059 Z1.984 I0. J1.587
X-43.768 Y45.7 Z1.971 I-1.546 J-0.359
G3 X-43.132 Z1.936 I0.318 J0.
X-43.45 Y46.018 Z1.919 I-0.318 J0.
G2 X-43.809 Y46.059 Z1.906 I0. J1.587
X-43.768 Y45.7 Z1.894 I-1.546 J-0.359
G3 X-43.132 Z1.859 I0.318 J0.
X-43.45 Y46.018 Z1.842 I-0.318 J0.
G2 X-43.809 Y46.059 Z1.829 I0. J1.587
X-43.768 Y45.7 Z1.816 I-1.546 J-0.359
G3 X-43.132 Z1.781 I0.318 J0.
X-43.45 Y46.018 Z1.764 I-0.318 J0.
G2 X-43.809 Y46.059 Z1.751 I0. J1.587
X-43.768 Y45.7 Z1.739 I-1.546 J-0.359
G3 X-43.132 Z1.704 I0.318 J0.
X-43.45 Y46.018 Z1.687 I-0.318 J0.
G2 X-43.809 Y46.059 Z1.674 I0. J1.587
X-43.768 Y45.7 Z1.661 I-1.546 J-0.359
G3 X-43.132 Z1.626 I0.318 J0.
X-43.45 Y46.018 Z1.609 I-0.318 J0.
G2 X-43.809 Y46.059 Z1.596 I0. J1.587
X-43.768 Y45.7 Z1.584 I-1.546 J-0.359
G3 X-43.132 Z1.549 I0.318 J0.
X-43.45 Y46.018 Z1.532 I-0.318 J0.
G2 X-43.809 Y46.059 Z1.519 I0. J1.587
X-43.768 Y45.7 Z1.506 I-1.546 J-0.359
G3 X-43.132 Z1.471 I0.318 J0.
X-43.45 Y46.018 Z1.454 I-0.318 J0.
G2 X-43.809 Y46.059 Z1.441 I0. J1.587
X-43.768 Y45.7 Z1.429 I-1.546 J-0.359
G3 X-43.132 Z1.394 I0.318 J0.
X-43.45 Y46.018 Z1.377 I-0.318 J0.
G2 X-43.809 Y46.059 Z1.364 I0. J1.587
X-43.768 Y45.7 Z1.351 I-1.546 J-0.359
G3 X-43.132 Z1.316 I0.318 J0.
X-43.45 Y46.018 Z1.299 I-0.318 J0.
G2 X-43.809 Y46.059 Z1.286 I0. J1.587
X-43.768 Y45.7 Z1.274 I-1.546 J-0.359
G3 X-43.132 Z1.239 I0.318 J0.
X-43.45 Y46.018 Z1.222 I-0.318 J0.
G2 X-43.809 Y46.059 Z1.209 I0. J1.587
X-43.768 Y45.7 Z1.196 I-1.546 J-0.359
G3 X-43.132 Z1.161 I0.318 J0.
X-43.45 Y46.018 Z1.144 I-0.318 J0.
G2 X-43.809 Y46.059 Z1.131 I0. J1.587
X-43.768 Y45.7 Z1.119 I-1.546 J-0.359
G3 X-43.132 Z1.084 I0.318 J0.
X-43.45 Y46.018 Z1.067 I-0.318 J0.
G2 X-43.809 Y46.059 Z1.054 I0. J1.587
X-43.768 Y45.7 Z1.041 I-1.546 J-0.359
G3 X-43.132 Z1.006 I0.318 J0.
X-43.45 Y46.018 Z0.989 I-0.318 J0.
G2 X-43.809 Y46.059 Z0.976 I0. J1.587
X-43.768 Y45.7 Z0.964 I-1.546 J-0.359
G3 X-43.132 Z0.929 I0.318 J0.
X-43.45 Y46.018 Z0.911 I-0.318 J0.
G2 X-43.809 Y46.059 Z0.899 I0. J1.587
X-43.768 Y45.7 Z0.886 I-1.546 J-0.359
G3 X-43.132 Z0.851 I0.318 J0.
X-43.45 Y46.018 Z0.834 I-0.318 J0.
G2 X-43.809 Y46.059 Z0.821 I0. J1.587
X-43.768 Y45.7 Z0.809 I-1.546 J-0.359
G3 X-43.132 Z0.774 I0.318 J0.
X-43.45 Y46.018 Z0.756 I-0.318 J0.
G2 X-43.809 Y46.059 Z0.744 I0. J1.587
X-43.768 Y45.7 Z0.731 I-1.546 J-0.359
G3 X-43.132 Z0.696 I0.318 J0.
X-43.45 Y46.018 Z0.679 I-0.318 J0.
G2 X-43.809 Y46.059 Z0.666 I0. J1.587
X-43.768 Y45.7 Z0.654 I-1.546 J-0.359
G3 X-43.132 Z0.619 I0.318 J0.
X-43.45 Y46.018 Z0.601 I-0.318 J0.
G2 X-43.809 Y46.059 Z0.589 I0. J1.587
X-43.768 Y45.7 Z0.576 I-1.546 J-0.359
G3 X-43.132 Z0.541 I0.318 J0.
X-43.45 Y46.018 Z0.524 I-0.318 J0.
G2 X-43.809 Y46.059 Z0.511 I0. J1.587
X-43.768 Y45.7 Z0.499 I-1.546 J-0.359
G3 X-43.132 Z0.464 I0.318 J0.
X-43.45 Y46.018 Z0.446 I-0.318 J0.
G2 X-43.809 Y46.059 Z0.434 I0. J1.587
X-43.768 Y45.7 Z0.421 I-1.546 J-0.359
G3 X-43.132 Z0.386 I0.318 J0.
X-43.45 Y46.018 Z0.369 I-0.318 J0.
G2 X-43.809 Y46.059 Z0.356 I0. J1.587
X-43.768 Y45.7 Z0.344 I-1.546 J-0.359
G3 X-43.132 Z0.309 I0.318 J0.
X-43.45 Y46.018 Z0.291 I-0.318 J0.
G2 X-43.809 Y46.059 Z0.279 I0. J1.587
X-43.768 Y45.7 Z0.266 I-1.546 J-0.359
G3 X-43.132 Z0.231 I0.318 J0.
X-43.45 Y46.018 Z0.214 I-0.318 J0.
G2 X-43.809 Y46.059 Z0.201 I0. J1.587
X-43.768 Y45.7 Z0.189 I-1.546 J-0.359
G3 X-43.132 Z0.154 I0.318 J0.
X-43.45 Y46.018 Z0.136 I-0.318 J0.
G2 X-43.809 Y46.059 Z0.124 I0. J1.587
X-43.768 Y45.7 Z0.111 I-1.546 J-0.359
G3 X-43.132 Z0.076 I0.318 J0.
X-43.45 Y46.018 Z0.059 I-0.318 J0.
G2 X-43.809 Y46.059 Z0.046 I0. J1.587
X-43.768 Y45.7 Z0.034 I-1.546 J-0.359
G3 X-43.132 Z-0.001 I0.318 J0.
X-43.45 Y46.018 Z-0.019 I-0.318 J0.
G2 X-43.809 Y46.059 Z-0.031 I0. J1.587
X-43.768 Y45.7 Z-0.044 I-1.546 J-0.359
G3 X-43.132 Z-0.079 I0.318 J0.
X-43.45 Y46.018 Z-0.096 I-0.318 J0.
G2 X-43.809 Y46.059 Z-0.109 I0. J1.587
X-43.768 Y45.7 Z-0.121 I-1.546 J-0.359
G3 X-43.132 Z-0.156 I0.318 J0.
X-43.45 Y46.018 Z-0.174 I-0.318 J0.
G2 X-43.809 Y46.059 Z-0.186 I0. J1.587
X-43.768 Y45.7 Z-0.199 I-1.546 J-0.359
G3 X-43.132 Z-0.234 I0.318 J0.
X-43.45 Y46.018 Z-0.251 I-0.318 J0.
G2 X-43.809 Y46.059 Z-0.264 I0. J1.587
X-43.768 Y45.7 Z-0.276 I-1.546 J-0.359
G3 X-43.132 Z-0.311 I0.318 J0.
X-43.45 Y46.018 Z-0.329 I-0.318 J0.
G2 X-43.809 Y46.059 Z-0.341 I0. J1.587
X-43.768 Y45.7 Z-0.354 I-1.546 J-0.359
G3 X-43.132 Z-0.389 I0.318 J0.
X-43.45 Y46.018 Z-0.406 I-0.318 J0.
G2 X-43.809 Y46.059 Z-0.419 I0. J1.587
X-43.768 Y45.7 Z-0.431 I-1.546 J-0.359
G3 X-43.132 Z-0.466 I0.318 J0.
X-43.45 Y46.018 Z-0.484 I-0.318 J0.
G2 X-43.809 Y46.059 Z-0.496 I0. J1.587
X-43.768 Y45.7 Z-0.509 I-1.546 J-0.359
G3 X-43.132 Z-0.544 I0.318 J0.
X-43.45 Y46.018 Z-0.561 I-0.318 J0.
G2 X-43.809 Y46.059 Z-0.574 I0. J1.587
X-43.768 Y45.7 Z-0.586 I-1.546 J-0.359
G3 X-43.132 Z-0.621 I0.318 J0.
X-43.45 Y46.018 Z-0.639 I-0.318 J0.
G2 X-43.809 Y46.059 Z-0.651 I0. J1.587
X-43.768 Y45.7 Z-0.664 I-1.546 J-0.359
G3 X-43.132 Z-0.699 I0.318 J0.
X-43.45 Y46.018 Z-0.716 I-0.318 J0.
G2 X-43.809 Y46.059 Z-0.729 I0. J1.587
X-43.768 Y45.7 Z-0.741 I-1.546 J-0.359
G3 X-43.132 Z-0.776 I0.318 J0.
X-43.45 Y46.018 Z-0.794 I-0.318 J0.
G2 X-43.809 Y46.059 Z-0.806 I0. J1.587
X-43.768 Y45.7 Z-0.819 I-1.546 J-0.359
G3 X-43.132 Z-0.854 I0.318 J0.
X-43.45 Y46.018 Z-0.871 I-0.318 J0.
G2 X-43.809 Y46.059 Z-0.884 I0. J1.587
X-43.768 Y45.7 Z-0.896 I-1.546 J-0.359
G3 X-43.132 Z-0.931 I0.318 J0.
X-43.45 Y46.018 Z-0.949 I-0.318 J0.
G2 X-43.809 Y46.059 Z-0.961 I0. J1.587
X-43.768 Y45.7 Z-0.974 I-1.546 J-0.359
G3 X-43.225 Y45.475 Z-1. I0.318 J0.
G0 Z5.
X43.17 Y45.849
G1 Z2.817 F300
X43.166 Y45.843 Z2.748 F609.6
G3 X43.157 Y45.822 Z2.682 I0.284 J-0.143
X43.145 Y45.788 Z2.623 I0.293 J-0.122
X43.135 Y45.741 Z2.573 I0.305 J-0.088
X43.133 Y45.683 Z2.535 I0.315 J-0.041
X43.143 Y45.619 Z2.51 I0.317 J0.017
X43.168 Y45.555 Z2.5 I0.307 J0.081
X43.768 Y45.7 Z2.47 I0.282 J0.145
G2 X43.809 Y46.059 Z2.458 I1.587 J0.
X43.45 Y46.018 Z2.445 I-0.359 J1.546
G3 Y45.382 Z2.41 I0. J-0.318
X43.768 Y45.7 Z2.393 I0. J0.318
G2 X43.809 Y46.059 Z2.38 I1.587 J0.
X43.45 Y46.018 Z2.368 I-0.359 J1.546
G3 Y45.382 Z2.333 I0. J-0.318
X43.768 Y45.7 Z2.315 I0. J0.318
G2 X43.809 Y46.059 Z2.303 I1.587 J0.
X43.45 Y46.018 Z2.29 I-0.359 J1.546
G3 Y45.382 Z2.255 I0. J-0.318
X43.768 Y45.7 Z2.238 I0. J0.318
G2 X43.809 Y46.059 Z2.225 I1.587 J0.
X43.45 Y46.018 Z2.213 I-0.359 J1.546
G3 Y45.382 Z2.178 I0. J-0.318
X43.768 Y45.7 Z2.16 I0. J0.318
G2 X43.809 Y46.059 Z2.148 I1.587 J0.
X43.45 Y46.018 Z2.135 I-0.359 J1.546
G3 Y45.382 Z2.1 I0. J-0.318
X43.768 Y45.7 Z2.083 I0. J0.318
G2 X43.809 Y46.059 Z2.07 I1.587 J0.
X43.45 Y46.018 Z2.058 I-0.359 J1.546
G3 Y45.382 Z2.023 I0. J-0.318
X43.768 Y45.7 Z2.005 I0. J0.318
G2 X43.809 Y46.059 Z1.993 I1.587 J0.
X43.45 Y46.018 Z1.98 I-0.359 J1.546
G3 Y45.382 Z1.945 I0. J-0.318
X43.768 Y45.7 Z1.928 I0. J0.318
G2 X43.809 Y46.059 Z1.915 I1.587 J0.
X43.45 Y46.018 Z1.903 I-0.359 J1.546
G3 Y45.382 Z1.868 I0. J-0.318
X43.768 Y45.7 Z1.85 I0. J0.318
G2 X43.809 Y46.059 Z1.838 I1.587 J0.
X43.45 Y46.018 Z1.825 I-0.359 J1.546
G3 Y45.382 Z1.79 I0. J-0.318
X43.768 Y45.7 Z1.773 I0. J0.318
G2 X43.809 Y46.059 Z1.76 I1.587 J0.
X43.45 Y46.018 Z1.748 I-0.359 J1.546
G3 Y45.382 Z1.713 I0. J-0.318
X43.768 Y45.7 Z1.695 I0. J0.318
G2 X43.809 Y46.059 Z1.683 I1.587 J0.
X43.45 Y46.018 Z1.67 I-0.359 J1.546
G3 Y45.382 Z1.635 I0. J-0.318
X43.768 Y45.7 Z1.618 I0. J0.318
G2 X43.809 Y46.059 Z1.605 I1.587 J0.
X43.45 Y46.018 Z1.593 I-0.359 J1.546
G3 Y45.382 Z1.558 I0. J-0.318
X43.768 Y45.7 Z1.54 I0. J0.318
G2 X43.809 Y46.059 Z1.528 I1.587 J0.
X43.45 Y46.018 Z1.515 I-0.359 J1.546
G3 Y45.382 Z1.48 I0. J-0.318
X43.768 Y45.7 Z1.463 I0. J0.318
G2 X43.809 Y46.059 Z1.45 I1.587 J0.
X43.45 Y46.018 Z1.438 I-0.359 J1.546
G3 Y45.382 Z1.403 I0. J-0.318
X43.768 Y45.7 Z1.385 I0. J0.318
G2 X43.809 Y46.059 Z1.373 I1.587 J0.
X43.45 Y46.018 Z1.36 I-0.359 J1.546
G3 Y45.382 Z1.325 I0. J-0.318
X43.768 Y45.7 Z1.308 I0. J0.318
G2 X43.809 Y46.059 Z1.295 I1.587 J0.
X43.45 Y46.018 Z1.283 I-0.359 J1.546
G3 Y45.382 Z1.248 I0. J-0.318
X43.768 Y45.7 Z1.23 I0. J0.318
G2 X43.809 Y46.059 Z1.218 I1.587 J0.
X43.45 Y46.018 Z1.205 I-0.359 J1.546
G3 Y45.382 Z1.17 I0. J-0.318
X43.768 Y45.7 Z1.153 I0. J0.318
G2 X43.809 Y46.059 Z1.14 I1.587 J0.
X43.45 Y46.018 Z1.128 I-0.359 J1.546
G3 Y45.382 Z1.093 I0. J-0.318
X43.768 Y45.7 Z1.075 I0. J0.318
G2 X43.809 Y46.059 Z1.063 I1.587 J0.
X43.45 Y46.018 Z1.05 I-0.359 J1.546
G3 Y45.382 Z1.015 I0. J-0.318
X43.768 Y45.7 Z0.998 I0. J0.318
G2 X43.809 Y46.059 Z0.985 I1.587 J0.
X43.45 Y46.018 Z0.973 I-0.359 J1.546
G3 Y45.382 Z0.938 I0. J-0.318
X43.768 Y45.7 Z0.92 I0. J0.318
G2 X43.809 Y46.059 Z0.908 I1.587 J0.
X43.45 Y46.018 Z0.895 I-0.359 J1.546
G3 Y45.382 Z0.86 I0. J-0.318
X43.768 Y45.7 Z0.843 I0. J0.318
G2 X43.809 Y46.059 Z0.83 I1.587 J0.
X43.45 Y46.018 Z0.818 I-0.359 J1.546
G3 Y45.382 Z0.783 I0. J-0.318
X43.768 Y45.7 Z0.765 I0. J0.318
G2 X43.809 Y46.059 Z0.753 I1.587 J0.
X43.45 Y46.018 Z0.74 I-0.359 J1.546
G3 Y45.382 Z0.705 I0. J-0.318
X43.768 Y45.7 Z0.688 I0. J0.318
G2 X43.809 Y46.059 Z0.675 I1.587 J0.
X43.45 Y46.018 Z0.663 I-0.359 J1.546
G3 Y45.382 Z0.628 I0. J-0.318
X43.768 Y45.7 Z0.61 I0. J0.318
G2 X43.809 Y46.059 Z0.598 I1.587 J0.
X43.45 Y46.018 Z0.585 I-0.359 J1.546
G3 Y45.382 Z0.55 I0. J-0.318
X43.768 Y45.7 Z0.533 I0. J0.318
G2 X43.809 Y46.059 Z0.52 I1.587 J0.
X43.45 Y46.018 Z0.508 I-0.359 J1.546
G3 Y45.382 Z0.473 I0. J-0.318
X43.768 Y45.7 Z0.455 I0. J0.318
G2 X43.809 Y46.059 Z0.443 I1.587 J0.
X43.45 Y46.018 Z0.43 I-0.359 J1.546
G3 Y45.382 Z0.395 I0. J-0.318
X43.768 Y45.7 Z0.378 I0. J0.318
G2 X43.809 Y46.059 Z0.365 I1.587 J0.
X43.45 Y46.018 Z0.353 I-0.359 J1.546
G3 Y45.382 Z0.318 I0. J-0.318
X43.768 Y45.7 Z0.3 I0. J0.318
G2 X43.809 Y46.059 Z0.288 I1.587 J0.
X43.45 Y46.018 Z0.275 I-0.359 J1.546
G3 Y45.382 Z0.24 I0. J-0.318
X43.768 Y45.7 Z0.223 I0. J0.318
G2 X43.809 Y46.059 Z0.21 I1.587 J0.
X43.45 Y46.018 Z0.198 I-0.359 J1.546
G3 Y45.382 Z0.163 I0. J-0.318
X43.768 Y45.7 Z0.145 I0. J0.318
G2 X43.809 Y46.059 Z0.133 I1.587 J0.
X43.45 Y46.018 Z0.12 I-0.359 J1.546
G3 Y45.382 Z0.085 I0. J-0.318
X43.768 Y45.7 Z0.068 I0. J0.318
G2 X43.809 Y46.059 Z0.055 I1.587 J0.
X43.45 Y46.018 Z0.043 I-0.359 J1.546
G3 Y45.382 Z0.008 I0. J-0.318
X43.768 Y45.7 Z-0.01 I0. J0.318
G2 X43.809 Y46.059 Z-0.022 I1.587 J0.
X43.45 Y46.018 Z-0.035 I-0.359 J1.546
G3 Y45.382 Z-0.07 I0. J-0.318
X43.768 Y45.7 Z-0.087 I0. J0.318
G2 X43.809 Y46.059 Z-0.1 I1.587 J0.
X43.45 Y46.018 Z-0.112 I-0.359 J1.546
G3 Y45.382 Z-0.147 I0. J-0.318
X43.768 Y45.7 Z-0.165 I0. J0.318
G2 X43.809 Y46.059 Z-0.177 I1.587 J0.
X43.45 Y46.018 Z-0.19 I-0.359 J1.546
G3 Y45.382 Z-0.225 I0. J-0.318
X43.768 Y45.7 Z-0.242 I0. J0.318
G2 X43.809 Y46.059 Z-0.255 I1.587 J0.
X43.45 Y46.018 Z-0.267 I-0.359 J1.546
G3 Y45.382 Z-0.302 I0. J-0.318
X43.768 Y45.7 Z-0.32 I0. J0.318
G2 X43.809 Y46.059 Z-0.332 I1.587 J0.
X43.45 Y46.018 Z-0.345 I-0.359 J1.546
G3 Y45.382 Z-0.38 I0. J-0.318
X43.768 Y45.7 Z-0.397 I0. J0.318
G2 X43.809 Y46.059 Z-0.41 I1.587 J0.
X43.45 Y46.018 Z-0.422 I-0.359 J1.546
G3 Y45.382 Z-0.457 I0. J-0.318
X43.768 Y45.7 Z-0.475 I0. J0.318
G2 X43.809 Y46.059 Z-0.487 I1.587 J0.
X43.45 Y46.018 Z-0.5 I-0.359 J1.546
G3 Y45.382 I0. J-0.318 F700
X43.768 Y45.7 I0. J0.318
G2 X43.809 Y46.059 I1.587 J0.
X43.45 Y46.018 I-0.359 J1.546
G3 Y45.382 Z-0.535 I0. J-0.318 F609.6
X43.768 Y45.7 Z-0.552 I0. J0.318
G2 X43.809 Y46.059 Z-0.565 I1.587 J0.
X43.45 Y46.018 Z-0.578 I-0.359 J1.546
G3 Y45.382 Z-0.612 I0. J-0.318
X43.768 Y45.7 Z-0.63 I0. J0.318
G2 X43.809 Y46.059 Z-0.642 I1.587 J0.
X43.45 Y46.018 Z-0.655 I-0.359 J1.546
G3 Y45.382 Z-0.69 I0. J-0.318
X43.768 Y45.7 Z-0.707 I0. J0.318
G2 X43.809 Y46.059 Z-0.72 I1.587 J0.
X43.45 Y46.018 Z-0.733 I-0.359 J1.546
G3 Y45.382 Z-0.767 I0. J-0.318
X43.768 Y45.7 Z-0.785 I0. J0.318
G2 X43.809 Y46.059 Z-0.797 I1.587 J0.
X43.45 Y46.018 Z-0.81 I-0.359 J1.546
G3 Y45.382 Z-0.845 I0. J-0.318
X43.768 Y45.7 Z-0.862 I0. J0.318
G2 X43.809 Y46.059 Z-0.875 I1.587 J0.
X43.45 Y46.018 Z-0.888 I-0.359 J1.546
G3 Y45.382 Z-0.922 I0. J-0.318
X43.768 Y45.7 Z-0.94 I0. J0.318
G2 X43.809 Y46.059 Z-0.952 I1.587 J0.
X43.45 Y46.018 Z-0.965 I-0.359 J1.546
G3 X43.133 Y45.698 Z-0.983 I0. J-0.318
X43.454 Y45.383 Z-1. I0.317 J0.002
X43.768 Y45.7 I-0.004 J0.317 F700
G3 X43.133 Y45.698 I0. J-0.318
X43.454 Y45.383 I0.317 J0.002
G0 Z5.
X43.599 Y-45.42
G1 Z2.817 F300
X43.593 Y-45.416 Z2.748 F609.6
G3 X43.572 Y-45.407 Z2.682 I-0.143 J-0.284
X43.538 Y-45.395 Z2.623 I-0.122 J-0.293
X43.491 Y-45.385 Z2.573 I-0.088 J-0.305
X43.433 Y-45.383 Z2.535 I-0.041 J-0.315
X43.369 Y-45.393 Z2.51 I0.017 J-0.317
X43.305 Y-45.418 Z2.5 I0.081 J-0.307
X43.45 Y-46.018 Z2.47 I0.145 J-0.282
G2 X43.809 Y-46.059 Z2.458 I0. J-1.587
X43.768 Y-45.7 Z2.445 I1.546 J0.359
G3 X43.132 Z2.41 I-0.318 J0.
X43.45 Y-46.018 Z2.393 I0.318 J0.
G2 X43.809 Y-46.059 Z2.38 I0. J-1.587
X43.768 Y-45.7 Z2.368 I1.546 J0.359
G3 X43.132 Z2.333 I-0.318 J0.
X43.45 Y-46.018 Z2.315 I0.318 J0.
G2 X43.809 Y-46.059 Z2.303 I0. J-1.587
X43.768 Y-45.7 Z2.29 I1.546 J0.359
G3 X43.132 Z2.255 I-0.318 J0.
X43.45 Y-46.018 Z2.238 I0.318 J0.
G2 X43.809 Y-46.059 Z2.225 I0. J-1.587
X43.768 Y-45.7 Z2.213 I1.546 J0.359
G3 X43.132 Z2.178 I-0.318 J0.
X43.45 Y-46.018 Z2.16 I0.318 J0.
G2 X43.809 Y-46.059 Z2.148 I0. J-1.587
X43.768 Y-45.7 Z2.135 I1.546 J0.359
G3 X43.132 Z2.1 I-0.318 J0.
X43.45 Y-46.018 Z2.083 I0.318 J0.
G2 X43.809 Y-46.059 Z2.07 I0. J-1.587
X43.768 Y-45.7 Z2.058 I1.546 J0.359
G3 X43.132 Z2.023 I-0.318 J0.
X43.45 Y-46.018 Z2.005 I0.318 J0.
G2 X43.809 Y-46.059 Z1.993 I0. J-1.587
X43.768 Y-45.7 Z1.98 I1.546 J0.359
G3 X43.132 Z1.945 I-0.318 J0.
X43.45 Y-46.018 Z1.928 I0.318 J0.
G2 X43.809 Y-46.059 Z1.915 I0. J-1.587
X43.768 Y-45.7 Z1.903 I1.546 J0.359
G3 X43.132 Z1.868 I-0.318 J0.
X43.45 Y-46.018 Z1.85 I0.318 J0.
G2 X43.809 Y-46.059 Z1.838 I0. J-1.587
X43.768 Y-45.7 Z1.825 I1.546 J0.359
G3 X43.132 Z1.79 I-0.318 J0.
X43.45 Y-46.018 Z1.773 I0.318 J0.
G2 X43.809 Y-46.059 Z1.76 I0. J-1.587
X43.768 Y-45.7 Z1.748 I1.546 J0.359
G3 X43.132 Z1.713 I-0.318 J0.
X43.45 Y-46.018 Z1.695 I0.318 J0.
G2 X43.809 Y-46.059 Z1.683 I0. J-1.587
X43.768 Y-45.7 Z1.67 I1.546 J0.359
G3 X43.132 Z1.635 I-0.318 J0.
X43.45 Y-46.018 Z1.618 I0.318 J0.
G2 X43.809 Y-46.059 Z1.605 I0. J-1.587
X43.768 Y-45.7 Z1.593 I1.546 J0.359
G3 X43.132 Z1.558 I-0.318 J0.
X43.45 Y-46.018 Z1.54 I0.318 J0.
G2 X43.809 Y-46.059 Z1.528 I0. J-1.587
X43.768 Y-45.7 Z1.515 I1.546 J0.359
G3 X43.132 Z1.48 I-0.318 J0.
X43.45 Y-46.018 Z1.463 I0.318 J0.
G2 X43.809 Y-46.059 Z1.45 I0. J-1.587
X43.768 Y-45.7 Z1.438 I1.546 J0.359
G3 X43.132 Z1.403 I-0.318 J0.
X43.45 Y-46.018 Z1.385 I0.318 J0.
G2 X43.809 Y-46.059 Z1.373 I0. J-1.587
X43.768 Y-45.7 Z1.36 I1.546 J0.359
G3 X43.132 Z1.325 I-0.318 J0.
X43.45 Y-46.018 Z1.308 I0.318 J0.
G2 X43.809 Y-46.059 Z1.295 I0. J-1.587
X43.768 Y-45.7 Z1.283 I1.546 J0.359
G3 X43.132 Z1.248 I-0.318 J0.
X43.45 Y-46.018 Z1.23 I0.318 J0.
G2 X43.809 Y-46.059 Z1.218 I0. J-1.587
X43.768 Y-45.7 Z1.205 I1.546 J0.359
G3 X43.132 Z1.17 I-0.318 J0.
X43.45 Y-46.018 Z1.153 I0.318 J0.
G2 X43.809 Y-46.059 Z1.14 I0. J-1.587
X43.768 Y-45.7 Z1.128 I1.546 J0.359
G3 X43.132 Z1.093 I-0.318 J0.
X43.45 Y-46.018 Z1.075 I0.318 J0.
G2 X43.809 Y-46.059 Z1.063 I0. J-1.587
X43.768 Y-45.7 Z1.05 I1.546 J0.359
G3 X43.132 Z1.015 I-0.318 J0.
X43.45 Y-46.018 Z0.998 I0.318 J0.
G2 X43.809 Y-46.059 Z0.985 I0. J-1.587
X43.768 Y-45.7 Z0.973 I1.546 J0.359
G3 X43.132 Z0.938 I-0.318 J0.
X43.45 Y-46.018 Z0.92 I0.318 J0.
G2 X43.809 Y-46.059 Z0.908 I0. J-1.587
X43.768 Y-45.7 Z0.895 I1.546 J0.359
G3 X43.132 Z0.86 I-0.318 J0.
X43.45 Y-46.018 Z0.843 I0.318 J0.
G2 X43.809 Y-46.059 Z0.83 I0. J-1.587
X43.768 Y-45.7 Z0.818 I1.546 J0.359
G3 X43.132 Z0.783 I-0.318 J0.
X43.45 Y-46.018 Z0.765 I0.318 J0.
G2 X43.809 Y-46.059 Z0.753 I0. J-1.587
X43.768 Y-45.7 Z0.74 I1.546 J0.359
G3 X43.132 Z0.705 I-0.318 J0.
X43.45 Y-46.018 Z0.688 I0.318 J0.
G2 X43.809 Y-46.059 Z0.675 I0. J-1.587
X43.768 Y-45.7 Z0.663 I1.546 J0.359
G3 X43.132 Z0.628 I-0.318 J0.
X43.45 Y-46.018 Z0.61 I0.318 J0.
G2 X43.809 Y-46.059 Z0.598 I0. J-1.587
X43.768 Y-45.7 Z0.585 I1.546 J0.359
G3 X43.132 Z0.55 I-0.318 J0.
X43.45 Y-46.018 Z0.533 I0.318 J0.
G2 X43.809 Y-46.059 Z0.52 I0. J-1.587
X43.768 Y-45.7 Z0.508 I1.546 J0.359
G3 X43.132 Z0.473 I-0.318 J0.
X43.45 Y-46.018 Z0.455 I0.318 J0.
G2 X43.809 Y-46.059 Z0.443 I0. J-1.587
X43.768 Y-45.7 Z0.43 I1.546 J0.359
G3 X43.132 Z0.395 I-0.318 J0.
X43.45 Y-46.018 Z0.378 I0.318 J0.
G2 X43.809 Y-46.059 Z0.365 I0. J-1.587
X43.768 Y-45.7 Z0.353 I1.546 J0.359
G3 X43.132 Z0.318 I-0.318 J0.
X43.45 Y-46.018 Z0.3 I0.318 J0.
G2 X43.809 Y-46.059 Z0.288 I0. J-1.587
X43.768 Y-45.7 Z0.275 I1.546 J0.359
G3 X43.132 Z0.24 I-0.318 J0.
X43.45 Y-46.018 Z0.223 I0.318 J0.
G2 X43.809 Y-46.059 Z0.21 I0. J-1.587
X43.768 Y-45.7 Z0.198 I1.546 J0.359
G3 X43.132 Z0.163 I-0.318 J0.
X43.45 Y-46.018 Z0.145 I0.318 J0.
G2 X43.809 Y-46.059 Z0.133 I0. J-1.587
X43.768 Y-45.7 Z0.12 I1.546 J0.359
G3 X43.132 Z0.085 I-0.318 J0.
X43.45 Y-46.018 Z0.068 I0.318 J0.
G2 X43.809 Y-46.059 Z0.055 I0. J-1.587
X43.768 Y-45.7 Z0.043 I1.546 J0.359
G3 X43.132 Z0.008 I-0.318 J0.
X43.45 Y-46.018 Z-0.01 I0.318 J0.
G2 X43.809 Y-46.059 Z-0.022 I0. J-1.587
X43.768 Y-45.7 Z-0.035 I1.546 J0.359
G3 X43.132 Z-0.07 I-0.318 J0.
X43.45 Y-46.018 Z-0.087 I0.318 J0.
G2 X43.809 Y-46.059 Z-0.1 I0. J-1.587
X43.768 Y-45.7 Z-0.112 I1.546 J0.359
G3 X43.132 Z-0.147 I-0.318 J0.
X43.45 Y-46.018 Z-0.165 I0.318 J0.
G2 X43.809 Y-46.059 Z-0.177 I0. J-1.587
X43.768 Y-45.7 Z-0.19 I1.546 J0.359
G3 X43.132 Z-0.225 I-0.318 J0.
X43.45 Y-46.018 Z-0.242 I0.318 J0.
G2 X43.809 Y-46.059 Z-0.255 I0. J-1.587
X43.768 Y-45.7 Z-0.267 I1.546 J0.359
G3 X43.132 Z-0.302 I-0.318 J0.
X43.45 Y-46.018 Z-0.32 I0.318 J0.
G2 X43.809 Y-46.059 Z-0.332 I0. J-1.587
X43.768 Y-45.7 Z-0.345 I1.546 J0.359
G3 X43.132 Z-0.38 I-0.318 J0.
X43.45 Y-46.018 Z-0.397 I0.318 J0.
G2 X43.809 Y-46.059 Z-0.41 I0. J-1.587
X43.768 Y-45.7 Z-0.422 I1.546 J0.359
G3 X43.132 Z-0.457 I-0.318 J0.
X43.45 Y-46.018 Z-0.475 I0.318 J0.
G2 X43.809 Y-46.059 Z-0.487 I0. J-1.587
X43.768 Y-45.7 Z-0.5 I1.546 J0.359
G3 X43.132 I-0.318 J0. F700
X43.45 Y-46.018 I0.318 J0.
G2 X43.809 Y-46.059 I0. J-1.587
X43.768 Y-45.7 I1.546 J0.359
G3 X43.132 Z-0.535 I-0.318 J0. F609.6
X43.45 Y-46.018 Z-0.552 I0.318 J0.
G2 X43.809 Y-46.059 Z-0.565 I0. J-1.587
X43.768 Y-45.7 Z-0.578 I1.546 J0.359
G3 X43.132 Z-0.612 I-0.318 J0.
X43.45 Y-46.018 Z-0.63 I0.318 J0.
G2 X43.809 Y-46.059 Z-0.642 I0. J-1.587
X43.768 Y-45.7 Z-0.655 I1.546 J0.359
G3 X43.132 Z-0.69 I-0.318 J0.
X43.45 Y-46.018 Z-0.707 I0.318 J0.
G2 X43.809 Y-46.059 Z-0.72 I0. J-1.587
X43.768 Y-45.7 Z-0.733 I1.546 J0.359
G3 X43.132 Z-0.767 I-0.318 J0.
X43.45 Y-46.018 Z-0.785 I0.318 J0.
G2 X43.809 Y-46.059 Z-0.797 I0. J-1.587
X43.768 Y-45.7 Z-0.81 I1.546 J0.359
G3 X43.132 Z-0.845 I-0.318 J0.
X43.45 Y-46.018 Z-0.862 I0.318 J0.
G2 X43.809 Y-46.059 Z-0.875 I0. J-1.587
X43.768 Y-45.7 Z-0.888 I1.546 J0.359
G3 X43.132 Z-0.922 I-0.318 J0.
X43.45 Y-46.018 Z-0.94 I0.318 J0.
G2 X43.809 Y-46.059 Z-0.952 I0. J-1.587
X43.768 Y-45.7 Z-0.965 I1.546 J0.359
G3 X43.448 Y-45.383 Z-0.983 I-0.318 J0.
X43.133 Y-45.704 Z-1. I0.002 J-0.317
X43.45 Y-46.018 I0.317 J0.004 F700
G3 X43.448 Y-45.383 I-0.318 J0.
X43.133 Y-45.704 I0.002 J-0.317
G0 Z5.
X-43.17 Y-45.849
G1 Z2.817 F300
X-43.166 Y-45.843 Z2.748 F609.6
G3 X-43.157 Y-45.822 Z2.682 I-0.284 J0.143
X-43.145 Y-45.788 Z2.623 I-0.293 J0.122
X-43.135 Y-45.741 Z2.573 I-0.305 J0.088
X-43.133 Y-45.683 Z2.535 I-0.315 J0.041
X-43.143 Y-45.619 Z2.51 I-0.317 J-0.017
X-43.168 Y-45.555 Z2.5 I-0.307 J-0.081
X-43.768 Y-45.7 Z2.47 I-0.282 J-0.145
G2 X-43.809 Y-46.059 Z2.458 I-1.587 J0.
X-43.45 Y-46.018 Z2.445 I0.359 J-1.546
G3 Y-45.382 Z2.41 I0. J0.318
X-43.768 Y-45.7 Z2.393 I0. J-0.318
G2 X-43.809 Y-46.059 Z2.38 I-1.587 J0.
X-43.45 Y-46.018 Z2.368 I0.359 J-1.546
G3 Y-45.382 Z2.333 I0. J0.318
X-43.768 Y-45.7 Z2.315 I0. J-0.318
G2 X-43.809 Y-46.059 Z2.303 I-1.587 J0.
X-43.45 Y-46.018 Z2.29 I0.359 J-1.546
G3 Y-45.382 Z2.255 I0. J0.318
X-43.768 Y-45.7 Z2.238 I0. J-0.318
G2 X-43.809 Y-46.059 Z2.225 I-1.587 J0.
X-43.45 Y-46.018 Z2.213 I0.359 J-1.546
G3 Y-45.382 Z2.178 I0. J0.318
X-43.768 Y-45.7 Z2.16 I0. J-0.318
G2 X-43.809 Y-46.059 Z2.148 I-1.587 J0.
X-43.45 Y-46.018 Z2.135 I0.359 J-1.546
G3 Y-45.382 Z2.1 I0. J0.318
X-43.768 Y-45.7 Z2.083 I0. J-0.318
G2 X-43.809 Y-46.059 Z2.07 I-1.587 J0.
X-43.45 Y-46.018 Z2.058 I0.359 J-1.546
G3 Y-45.382 Z2.023 I0. J0.318
X-43.768 Y-45.7 Z2.005 I0. J-0.318
G2 X-43.809 Y-46.059 Z1.993 I-1.587 J0.
X-43.45 Y-46.018 Z1.98 I0.359 J-1.546
G3 Y-45.382 Z1.945 I0. J0.318
X-43.768 Y-45.7 Z1.928 I0. J-0.318
G2 X-43.809 Y-46.059 Z1.915 I-1.587 J0.
X-43.45 Y-46.018 Z1.903 I0.359 J-1.546
G3 Y-45.382 Z1.868 I0. J0.318
X-43.768 Y-45.7 Z1.85 I0. J-0.318
G2 X-43.809 Y-46.059 Z1.838 I-1.587 J0.
X-43.45 Y-46.018 Z1.825 I0.359 J-1.546
G3 Y-45.382 Z1.79 I0. J0.318
X-43.768 Y-45.7 Z1.773 I0. J-0.318
G2 X-43.809 Y-46.059 Z1.76 I-1.587 J0.
X-43.45 Y-46.018 Z1.748 I0.359 J-1.546
G3 Y-45.382 Z1.713 I0. J0.318
X-43.768 Y-45.7 Z1.695 I0. J-0.318
G2 X-43.809 Y-46.059 Z1.683 I-1.587 J0.
X-43.45 Y-46.018 Z1.67 I0.359 J-1.546
G3 Y-45.382 Z1.635 I0. J0.318
X-43.768 Y-45.7 Z1.618 I0. J-0.318
G2 X-43.809 Y-46.059 Z1.605 I-1.587 J0.
X-43.45 Y-46.018 Z1.593 I0.359 J-1.546
G3 Y-45.382 Z1.558 I0. J0.318
X-43.768 Y-45.7 Z1.54 I0. J-0.318
G2 X-43.809 Y-46.059 Z1.528 I-1.587 J0.
X-43.45 Y-46.018 Z1.515 I0.359 J-1.546
G3 Y-45.382 Z1.48 I0. J0.318
X-43.768 Y-45.7 Z1.463 I0. J-0.318
G2 X-43.809 Y-46.059 Z1.45 I-1.587 J0.
X-43.45 Y-46.018 Z1.438 I0.359 J-1.546
G3 Y-45.382 Z1.403 I0. J0.318
X-43.768 Y-45.7 Z1.385 I0. J-0.318
G2 X-43.809 Y-46.059 Z1.373 I-1.587 J0.
X-43.45 Y-46.018 Z1.36 I0.359 J-1.546
G3 Y-45.382 Z1.325 I0. J0.318
X-43.768 Y-45.7 Z1.308 I0. J-0.318
G2 X-43.809 Y-46.059 Z1.295 I-1.587 J0.
X-43.45 Y-46.018 Z1.283 I0.359 J-1.546
G3 Y-45.382 Z1.248 I0. J0.318
X-43.768 Y-45.7 Z1.23 I0. J-0.318
G2 X-43.809 Y-46.059 Z1.218 I-1.587 J0.
X-43.45 Y-46.018 Z1.205 I0.359 J-1.546
G3 Y-45.382 Z1.17 I0. J0.318
X-43.768 Y-45.7 Z1.153 I0. J-0.318
G2 X-43.809 Y-46.059 Z1.14 I-1.587 J0.
X-43.45 Y-46.018 Z1.128 I0.359 J-1.546
G3 Y-45.382 Z1.093 I0. J0.318
X-43.768 Y-45.7 Z1.075 I0. J-0.318
G2 X-43.809 Y-46.059 Z1.063 I-1.587 J0.
X-43.45 Y-46.018 Z1.05 I0.359 J-1.546
G3 Y-45.382 Z1.015 I0. J0.318
X-43.768 Y-45.7 Z0.998 I0. J-0.318
G2 X-43.809 Y-46.059 Z0.985 I-1.587 J0.
X-43.45 Y-46.018 Z0.973 I0.359 J-1.546
G3 Y-45.382 Z0.938 I0. J0.318
X-43.768 Y-45.7 Z0.92 I0. J-0.318
G2 X-43.809 Y-46.059 Z0.908 I-1.587 J0.
X-43.45 Y-46.018 Z0.895 I0.359 J-1.546
G3 Y-45.382 Z0.86 I0. J0.318
X-43.768 Y-45.7 Z0.843 I0. J-0.318
G2 X-43.809 Y-46.059 Z0.83 I-1.587 J0.
X-43.45 Y-46.018 Z0.818 I0.359 J-1.546
G3 Y-45.382 Z0.783 I0. J0.318
X-43.768 Y-45.7 Z0.765 I0. J-0.318
G2 X-43.809 Y-46.059 Z0.753 I-1.587 J0.
X-43.45 Y-46.018 Z0.74 I0.359 J-1.546
G3 Y-45.382 Z0.705 I0. J0.318
X-43.768 Y-45.7 Z0.688 I0. J-0.318
G2 X-43.809 Y-46.059 Z0.675 I-1.587 J0.
X-43.45 Y-46.018 Z0.663 I0.359 J-1.546
G3 Y-45.382 Z0.628 I0. J0.318
X-43.768 Y-45.7 Z0.61 I0. J-0.318
G2 X-43.809 Y-46.059 Z0.598 I-1.587 J0.
X-43.45 Y-46.018 Z0.585 I0.359 J-1.546
G3 Y-45.382 Z0.55 I0. J0.318
X-43.768 Y-45.7 Z0.533 I0. J-0.318
G2 X-43.809 Y-46.059 Z0.52 I-1.587 J0.
X-43.45 Y-46.018 Z0.508 I0.359 J-1.546
G3 Y-45.382 Z0.473 I0. J0.318
X-43.768 Y-45.7 Z0.455 I0. J-0.318
G2 X-43.809 Y-46.059 Z0.443 I-1.587 J0.
X-43.45 Y-46.018 Z0.43 I0.359 J-1.546
G3 Y-45.382 Z0.395 I0. J0.318
X-43.768 Y-45.7 Z0.378 I0. J-0.318
G2 X-43.809 Y-46.059 Z0.365 I-1.587 J0.
X-43.45 Y-46.018 Z0.353 I0.359 J-1.546
G3 Y-45.382 Z0.318 I0. J0.318
X-43.768 Y-45.7 Z0.3 I0. J-0.318
G2 X-43.809 Y-46.059 Z0.288 I-1.587 J0.
X-43.45 Y-46.018 Z0.275 I0.359 J-1.546
G3 Y-45.382 Z0.24 I0. J0.318
X-43.768 Y-45.7 Z0.223 I0. J-0.318
G2 X-43.809 Y-46.059 Z0.21 I-1.587 J0.
X-43.45 Y-46.018 Z0.198 I0.359 J-1.546
G3 Y-45.382 Z0.163 I0. J0.318
X-43.768 Y-45.7 Z0.145 I0. J-0.318
G2 X-43.809 Y-46.059 Z0.133 I-1.587 J0.
X-43.45 Y-46.018 Z0.12 I0.359 J-1.546
G3 Y-45.382 Z0.085 I0. J0.318
X-43.768 Y-45.7 Z0.068 I0. J-0.318
G2 X-43.809 Y-46.059 Z0.055 I-1.587 J0.
X-43.45 Y-46.018 Z0.043 I0.359 J-1.546
G3 Y-45.382 Z0.008 I0. J0.318
X-43.768 Y-45.7 Z-0.01 I0. J-0.318
G2 X-43.809 Y-46.059 Z-0.022 I-1.587 J0.
X-43.45 Y-46.018 Z-0.035 I0.359 J-1.546
G3 Y-45.382 Z-0.07 I0. J0.318
X-43.768 Y-45.7 Z-0.087 I0. J-0.318
G2 X-43.809 Y-46.059 Z-0.1 I-1.587 J0.
X-43.45 Y-46.018 Z-0.112 I0.359 J-1.546
G3 Y-45.382 Z-0.147 I0. J0.318
X-43.768 Y-45.7 Z-0.165 I0. J-0.318
G2 X-43.809 Y-46.059 Z-0.177 I-1.587 J0.
X-43.45 Y-46.018 Z-0.19 I0.359 J-1.546
G3 Y-45.382 Z-0.225 I0. J0.318
X-43.768 Y-45.7 Z-0.242 I0. J-0.318
G2 X-43.809 Y-46.059 Z-0.255 I-1.587 J0.
X-43.45 Y-46.018 Z-0.267 I0.359 J-1.546
G3 Y-45.382 Z-0.302 I0. J0.318
X-43.768 Y-45.7 Z-0.32 I0. J-0.318
G2 X-43.809 Y-46.059 Z-0.332 I-1.587 J0.
X-43.45 Y-46.018 Z-0.345 I0.359 J-1.546
G3 Y-45.382 Z-0.38 I0. J0.318
X-43.768 Y-45.7 Z-0.397 I0. J-0.318
G2 X-43.809 Y-46.059 Z-0.41 I-1.587 J0.
X-43.45 Y-46.018 Z-0.422 I0.359 J-1.546
G3 Y-45.382 Z-0.457 I0. J0.318
X-43.768 Y-45.7 Z-0.475 I0. J-0.318
G2 X-43.809 Y-46.059 Z-0.487 I-1.587 J0.
X-43.45 Y-46.018 Z-0.5 I0.359 J-1.546
G3 Y-45.382 I0. J0.318 F700
X-43.768 Y-45.7 I0. J-0.318
G2 X-43.809 Y-46.059 I-1.587 J0.
X-43.45 Y-46.018 I0.359 J-1.546
G3 Y-45.382 Z-0.535 I0. J0.318 F609.6
X-43.768 Y-45.7 Z-0.552 I0. J-0.318
G2 X-43.809 Y-46.059 Z-0.565 I-1.587 J0.
X-43.45 Y-46.018 Z-0.578 I0.359 J-1.546
G3 Y-45.382 Z-0.612 I0. J0.318
X-43.768 Y-45.7 Z-0.63 I0. J-0.318
G2 X-43.809 Y-46.059 Z-0.642 I-1.587 J0.
X-43.45 Y-46.018 Z-0.655 I0.359 J-1.546
G3 Y-45.382 Z-0.69 I0. J0.318
X-43.768 Y-45.7 Z-0.707 I0. J-0.318
G2 X-43.809 Y-46.059 Z-0.72 I-1.587 J0.
X-43.45 Y-46.018 Z-0.733 I0.359 J-1.546
G3 Y-45.382 Z-0.767 I0. J0.318
X-43.768 Y-45.7 Z-0.785 I0. J-0.318
G2 X-43.809 Y-46.059 Z-0.797 I-1.587 J0.
X-43.45 Y-46.018 Z-0.81 I0.359 J-1.546
G3 Y-45.382 Z-0.845 I0. J0.318
X-43.768 Y-45.7 Z-0.862 I0. J-0.318
G2 X-43.809 Y-46.059 Z-0.875 I-1.587 J0.
X-43.45 Y-46.018 Z-0.888 I0.359 J-1.546
G3 Y-45.382 Z-0.922 I0. J0.318
X-43.768 Y-45.7 Z-0.94 I0. J-0.318
G2 X-43.809 Y-46.059 Z-0.952 I-1.587 J0.
X-43.45 Y-46.018 Z-0.965 I0.359 J-1.546
G3 X-43.133 Y-45.698 Z-0.983 I0. J0.318
X-43.454 Y-45.383 Z-1. I-0.317 J-0.002
X-43.768 Y-45.7 I0.004 J-0.317 F700
G3 X-43.133 Y-45.698 I0. J0.318
X-43.454 Y-45.383 I-0.317 J-0.002
G0 Z15.
M5
G53 Z0.
M30
- 7,658 Themen
- 58 Online
