UCCNC softlimits easy with remote control XHC-HB04
UCCNC allows to set softlimits to give more safety to the system. Unfortunately the configuration needs always a lot of configuration steps until it runs. I’ve written some easy macros and modified the defaultscreen of UCCNC to make it very easy and comfortable. 🙂
You need UCCNC in version 1.2x (here I use 1.2020 from free-download www.CNCdrive.com ;of course you need a license from Stepcraft or CNCdrive if you want to operate UCCNC!!!).
Also you need a XHC-HB04 from ebay: POST (it's my German post but there's a link to ebay...)
How to do:
Rename your original “Defaultscreenset.ssf” file to “Defaultscreenset-original.ssf”.
- Place the attached macros to the macro folder of UCCNC.
- Place the attached screen to the “screens” folder of UCCNC.
- Click on “Configurations” and then on “General settings”. Click on “configure plugins” and
- click on the configure of “XHC-HB04 pendant”. Make the changes as you see in the attached screenshot with exception of the Macro7 (it’s not necessary for the softlimits).
- Now APPLY settings and SAVE settings.
- Now restart UCCNC and you should see a modified RUN screen (upper right corner).
Withyour remote now go to the most left back position and press MACRO-1 button. You will get a short response from the x/y motors.
Now go to the most allowed right front position and press MACRO-2. Same response…
Now press MACRO-3. On the RUN screen the LED (Softlimit active) should now be GREEN.
Check with your handwheel if the softlimit is working.
Info about my setting: on the y-axis the “DIRECTION POSITIVE” is enabled (“checked”).
I did not add a macro or modified the macros for the Z-axis. You are free to do!
Hope it runs and I didn't foget any info you need. So come back with questions, I will help.
Hartmut
ESTLCAM & QCAD
DK5LH/G11
Depending on your direction setting of the Y-axis the macro maybe should have a different setting.
Here´s a modified zip file:
The differences are with the commands:
AS3.Setfield(yoriginalpos, 26);
AS3.Validatefield(26);
If the limits are not set correctly exchange the values by (27) or (26) in both files (26 in one and 27 in the other)
Hartmut
ESTLCAM & QCAD
DK5LH/G11
- 7,660 Themen
- 74 Online
