UCCNC and JoyPad
Hello All.
It is possible to configure a JoyPad to work under UCCNC? If so how it can be done?
Stepcraft 2 430
Kress 800 FME
UCCNC + UC100
Cut2D Desktop
![Michael Michael](http://stepcraft-systems.com/wp-content/uploads/wpforo/avatars/mikath_30837.jpg)
You have this one:
UCR200
I have this one and I´m very happy with it.
You could also use an Xbox controller.
/Mika
Stepcraft M.1000 + HIWIN Ball Screw + Semi-Closed Loop System + MM-1000 DI + Automatic Tool Changer + 2 Rows Tool Magazine Pneumatic Lifting + Engraving Laser DL445 + 4th Axis + Aluminum T-slot table + 3D Touch Probe + UCR201 + UCCNC + VCarve Pro + Cut3D + CorelDraw 2018 + Autodesk Inventor
![Andrzej Zywiol Andrzej Zywiol](http://stepcraft-systems.com/wp-content/uploads/wpforo/avatars/FaFiNoS_28909.jpg)
I have this one: Wi XHC HB04
It works perfectly with Mach3 and UCCNC v1.2020
S600 v2, HF500, FME 1050, Industrial quality small HF spindle and many many other things.
Are there any differences between the drivers for UCCNC and MACH3?
I found this one on ebay: Handwheel
There's no word about UCCNC compatibility and therefore I'm a little bit afraid that it will not work...
UPDATE: I found a "XHC-HB04_pendant.dll" in the latest UCCNC SW installation. SO should work 🙂 Thanks! 🙂 🙂 🙂
Hartmut
ESTLCAM & QCAD
DK5LH/G11
Today I got my handwheel after 3 days delivery directly from a store in Germay. Works pretty well! 🙂 For those who want to buy it also some additional infos:
- the plugin from CNCDRIVE works also on older UCCNC versions! 🙂
- the plugin is a Beta; no support for MACRO buttons or configuration at the moment 🙁
- the handwheel works only if it has contact to the 2.4GHz stick (otherwise the LED and display will only flash up a second; no comment in the manuals!!!)
- my driver CD contains a fully licenced MACH3 (it told that during installation...) but the setup file is corrupt; so no chance to get in running; on the other hand I tried the demo...too much features and configurations...I LOVE UCCNC...
- no backlight in the display
I just need some basic functions, so great unit for less money... :woohoo:
I'm just adding a short video and some pictures in the German section...need some time for upload, so have look later on it...
Hartmut
ESTLCAM & QCAD
DK5LH/G11
- 7,510 Themen
- 9 Online
