UCCNC software limits reached
Hi All,
Today I wanted to create my first object using my step craft CNC. No new to the machine and overal to CNC. So I'm having a few problems.
I drew my object using Fusion 360, awesome software btw. Then I generated my tool paths using Fusions CAM processor for UCCNC.
I loaded the file. Once I pressed 'cycle start' in UCCNC I refuses to do so because Z soft limit has been reached. (Z is 370 while soft limit is 200).
This is probably specified in my CAM G code file. But I don't know how to address this issue in fusion 360. Why am I having this issue, how can I resolve it?
FYI I check the clearance off all my toolpaths and none of them is above 50mm. So where is this issue coming from.
Attached my g-code file.
pls. use the button in UCCNC to do the reference driving for your Stepcraft before you start to mill.
After that, go to your start position and set the 0 position for your part (X,Y, and also Z)
Now it should work.
BR
Roy
MfG
Roy
... Once I pressed 'cycle start' in UCCNC I refuses to do so because Z soft limit has been reached. (Z is 370 while soft limit is 200).
FYI I check the clearance off all my toolpaths and none of them is above 50mm. So where is this issue coming from.Attached my g-code file.
The easy way is to switch OFF the SW limits in UCCNC...
Hartmut
ESTLCAM & QCAD
DK5LH/G11
- 10 Online
