stepcraft 300 win10
is there any possible way to make the stepcraft work with win10. if not i guess ill have to go buy a new comp.
Why not?
Which Software do you mean? If I remember right there is (was?) a problem with UCCNC, which should be fixed in a newer version.
WinPC NC or EstlCAM work fine, don't they? Don't know if Mach runs.
The only posible Problem could be the missing parallel port.
There are USB interfaces like uc100
So where is the Problem?
im completely new and dumb on cnc all together so that may be the problem lol. but win 10 wont recognize the usb 100 when i hook it up. i got it on a old laptop now, but i can not get any axis to move from uccnc. i also cant get uccnc to find my license code. so its running in demo mode. that could be the problem to idk.
on the parallel adapter there is two lights a green one and a blue one. the blue one never comes on.
if it runs in demo mode then it has not found the drivers.
the UCCNC will tell you specifically if it cannot find the license key.
you need a blue light on the module when you open the UCCNC
if you have W10 then you may have to enable the .net framework (but you have the UCCNC running so this is no the issue).
manual here
you have to enable .Net 3.5 compatibility option in windows
if the .net framework is not configured then the UCCNC won't run... but you have a different issue..
the drivers.
another thing that can overcome this if you are having drivers issues is to run the mach3 autoinstaller
available here
I got that part fixed. it jogs smoothly on all axis. now when I try the test cut from uccnc it says soft limits reached. same thing on vetric photo carves test cut. how do I fix that?
can't find much info online.
There is a checker box on one of the configuration pages. You have to UNCHECK (disable) the soft-limits.
It is written on page 17 of your manual MANUAL
If you want to use the soft-limits, you have to set the soft-limits relativly to your work-piece coordinates and then activate the soft-limits. I do not use the soft-limits. It is not needed but just a piece of safety.
Hartmut
ESTLCAM & QCAD
DK5LH/G11
ty very much. got it going. now to figure out how to design and cut my product. trying fusion 360 out. may give vectric a try idk yet any suggestions for a newbie?
I started December last year therefore I'm also a newbie...but I recommend QCAD
You can download a free version which works 100% but after I think 15min some features will be disabled.
The full version costs 33Euro which isn't too much. I have bought the full version and a seminar-handbook as a bundle: QCAD-order
I used the handbook for 3-4 evenings following all examples given there. You will need only one or two hand full of features for most projects...and your experience will grow with every project.
QCAd produces e.g. DXF files which can be handled e.g. by ESTLCAM as a good and very easy to handle CAM SW: ESTLCAM The only problem at the moment is, that it's written in German and translation into English and other languages is ongoing. You can ask Christian, when a English version is available: [email protected]
Hartmut
ESTLCAM & QCAD
DK5LH/G11
anyone want to take a pic of what I'm wanting and turn it into something I can cut out lol. ill pay. I need to be cutting product to afford to continue learning lol.
I'm also familiar with QCAD - show me a pic of your desired project and maybe I get you started with a CAD drawing ...
I would recommend to design/modify something like that with a 3D Program. QCAD works just as a 2D Program.
What's about a little internet research? No need to reinvent the wheel again ... 😉
my attempts at design one in fusion 360 have failed at best lol. I will look into qcad maybe I can get the hang of it. hard to learn something like that on limited time. by the time I get a chance to attempt it again I have done forgot all the controls of fusion and back to google I go.
- 27 Online
