UCCNC Problems
I have a reoccurring issue where after 2-4 cycles of loading a new file, UCCNC will stop updating the screen and sending signals to the USB unless i keep moving the mouse. The machine is not going to sleep, or starting the screen saver or anything else. Just chokes. I'm on Windows 8 still.
I have disabled all the Power Saving bs in the USB and any other hardware i could find in the device manager.
The only thing that seems to fix the issue is a Shut Down and Startup. Restart does not fix the issue surprisingly enough.
Computer:
ASUS T100TAM-C12-GR, 10.1" - Detachable 2-in-1 Touchscreen Laptop - Intel Atom Z3775 - 64GB HD - 2GB RAM - Win8.1
The processor seems to only be running at 20% load and there are no other indicators of a bandwidth hog anywhere so I can only guess it is a Adobe thing...
Stepcraft 2 420
500 Watt Spindle
3D Printing System
3d Probe
T-Slot Table
Tooling:
1/8" 60 Deg 4 Flute V Bit
1/8" 4-Flute Square Nose End Mill
1/8" 2 Flute Ball Nose End Mill
1/16" 2 Flute Ball Nose End Mill
UCCNC and VCarve Pro
Total Newbie!
How old is PC?
sounds like not enough resources.
disable anti virus etc also that can cause issues sometimes.
It is less than a year old and I don't have any antivirus since it doesn't really go online. I do have Windows defender going though.
Stepcraft 2 420
500 Watt Spindle
3D Printing System
3d Probe
T-Slot Table
Tooling:
Total Newbie!
![Javier Valencia Rodriguez Javier Valencia Rodriguez](http://stepcraft-systems.com/wp-content/uploads/wpforo/avatars/jvalencia_29638.jpg)
Well, the problem here is that it's a tablet. Don't expect lots of resources/speed from it.
2GB ram is very few for Win8 alone.
I think your device is doing disk swap after a while.
Stepcraft 2 840
Kress 800 FME
UCCNC + UC100
V-Carve + QCad
If your computer is dedicated to UCCNC then go through the MSCONFIG startup and services menus and stop anything that isn't strictly relevant to your operations. Virus software is a good first candidate, then things like Skype and Dropbox - anything that has to do with on-line activity can disrupt things.
Just experiment a little - you will be surprised how much can be culled without affecting UCCNC.
When I first started I bought a really cheap refurbished Dell 610 running WinXP Prof. No internet connection needed, just transfer required milling data from my main PC via a USB stick. I went through the culling process anyway, and never have any problems or glitches
Incidentally, I noticed that the latest revision of UCCNC is V1.2005 and that it uses OpenGL for graphics. I couldn't find a link to download when I last looked at "cncdrive.com". It is probably worth updating from V1.1027 and it might well solve your problem straight away if you can grab a copy.
UC100 + UCCNC
Version 1.2 has my problems solved it seems 🙂
Stepcraft 2 420
500 Watt Spindle
3D Printing System
3d Probe
T-Slot Table
Tooling:
Total Newbie!
I have the same exact problem and I'm on a 2 month old desktop with win 10. no internet going to it either.
mine had been running good all day. but it updated again after i reset it back to factory settings. now its doing the same thing again. where do i get the latest version of uccnc at
1.2016 is on the UCCNC site.
1.2016 has the open GL GUI.
i cant find the download. will i have to purchase a new license?
found it and i am amazed. its super fast loading and when i hit go to zero it goes to zero instead of drilling hole where i don't want it.
- 7,510 Themen
- 11 Online
