UCCNC on Windows 10 Pro x64.
![Michael Michael](http://stepcraft-systems.com/wp-content/uploads/wpforo/avatars/mikath_30837.jpg)
Is UCCNC running on Windows 10 Pro x64?
/Mika
Stepcraft M.1000 + HIWIN Ball Screw + Semi-Closed Loop System + MM-1000 DI + Automatic Tool Changer + 2 Rows Tool Magazine Pneumatic Lifting + Engraving Laser DL445 + 4th Axis + Aluminum T-slot table + 3D Touch Probe + UCR201 + UCCNC + VCarve Pro + Cut3D + CorelDraw 2018 + Autodesk Inventor
Hi Mika,
yes, CNCdrives says:
http://cncdrive.com/UCCNC.html
Compatible OP systems: Windows XP, 7, 8, 8.1, 10 on all both 32 and 64bit versions.
Thank You for fast reply!!!
Strange, maby it´s something wrong with my cd from Stepcraft, cause UCCNC will not start install... 🙁
I don´t have a Win 7 machine so I can´t try on Win 7...
/Mika
I tested the latest version from cncdrive and same thing as my cd from Stepcraft, NOTHING happens!!!
/Mika
Hi Mika,
i dont know, but if it works, try this:
Right mouse on the setupfile and then "Run as Administrator" (similar to higher rights).
Because i am not using windows 10, i can not discribe it very pretty in detail.
Grüße von der Wasserkuppe.
I have tried it too, but it was the same thing. 🙁
/Mika
For sure - it should work.
unless it is related to the latest issue with flash from adobe. There is a bug in the flash player that causes applications not to launch.
this could be the issue.
See here
On Win 10 there's an issue with the latest security update, but with win7 I don't know.
I tried v. 19 of Flash, but still the install won´t launch...
Now I have tried on two Win 10 computers, one of them is a Mac with Parallels Desktop. On Win 7 it works on my Mac with Parallels Desktop.
Hope they fix Win 10 soon or the OpenGL version will release soon.
Should I hope for the OpenGL first or... ???
/Mika
This is what happens when I try to run as admin...
lnWhbuJbu-g
/Mika
Tried to install on a new version of Win 10 without any updates, and still I can not install UCCNC.
/Mika
probably a stupid question - I assume you have read the UCCNC users manual software pre-requirements for windows 8/10.
Page 4 - .net framework details.
Read the section about windows 8 as this is the same as for 10.
No, there are no stupid questions!!!
Yes, I have... :dry:
/Mika
If it wont run and its not latest updated version with flash player then it must be the .net framework. We've yet to see a computer (300+) where it won't work.
We also have a lot of W10 users.
for sure the .net framework is enabled and installed?
You are AWESOME Rory!!! 😛
I´m a Mac-guy, and not a PC.guy...
... but now it works!!!
What I did was I opend regedit and looked in: HKEY_LOCAL_MACHINE/SOFTWARE/MicrosoftNET Framework Setup/NDP
Here I only found v4 and v4.0, and not v2 and v3.5
D/L this file: http://download.microsoft.com/download/c/d/c/cdc0f321-4f72-4a08-9bac-082f3692ecd9/DotNetFx35Client.exe .
Installed it och restart.
Boom, UCNCN installd and run like a charm!!! 😆
No fixing with Flash only the liked file.
/Mika
- 7,670 Themen
