Maybe simple question CUT2D
If i set my artwork in CUT2D and set all preferences (Dept of various toolpaths, drilling toolpaths, inlay toolpaths) in one design and export it (WinPC-NC ATC Arcs MM *.nc) to WINPC-NC does it import all depth/heights of the toolpaths? Or do i need to set the layers again with depth and speed (like the starter brochure explains in WINPX_NC)?
I hope you get my question. :ohmy:
![Javier Valencia Rodriguez Javier Valencia Rodriguez](http://stepcraft-systems.com/wp-content/uploads/wpforo/avatars/jvalencia_29638.jpg)
Yes it does. The .NC file has all the code needed to cut your toolpath as you defined it.
Stepcraft 2 840
Kress 800 FME
UCCNC + UC100
V-Carve + QCad
do you use the "starter" version of WinPC-NC?
In this case: it cannot open .nc files ("g-code") but requires .plt (HPGL) instead.
Hi Christian,
I only have a .NC file for WinPC-NC.
Wich do you use?
So i used "Generic HPGL Arcs (mm) (*.plt) but is only exports one cut layer and has a weird starting point. I use WinPC-NC Starter
Starter only allows 2 layers. Two layers means the first 2 tools in EstlCAM. The layers can be en-/disabled with the small numbers below the menu bar.
The starting point can be changed somewhere in the WinPC settings.
Thank you. I didn't understand that before installing. What should i use/buy? Im not so technical but want to export and use more then two layers. I allraid bought cut 2d (basic).
You can upgrade from Cut2D to VCarve according to the Vectric website
UC100 + UCCNC
But then i still have the problem that WinPC-NC starter only imports 2 layers, right?
the limiting factor in this case is WinPC-NC.
You either need to upgrade WinPC-NC or use a different control software altogether.
(By the way Estlcam has a built in CNC controller - it just requires an Arduino UNO.)
Hi chris,
Thanks. I think the cheapest and easy way is to upgrade winPC-NC right?
Which should i use:
Hi
If it were my choice I would go with UCCNC every time. This accepts standard Gcode commands as well as DXF files
Easy to learn, use and configure, and uses a USB to parallel converter "dongle" that does all the high speed control wizardry. This relieves the host PC/Laptop of a huge processing load so you can use a very low spec machine. I personally use an old refurbished Dell 610 running XP professional just to run my SC 420/2 - I was therefore able to strip out a lot of unnecessary software to make it as bomb proof as possible.
I have no connection to this software other than being a satisfied user.
Peter
UC100 + UCCNC
Well ... the argument with the USB 2 parallel does not really count, because that's exactly what the WinPC USB board is doing as well ... same is true for EstlCAMs Arduino board.
I use EstlCAM + Arduino with an old Netbook.
Prices:
WinPC update 200€ + EstlCAM 35€
EstlCAM 35€ + Arduino 35€
UCCNC + UCCNC USB board ?
In June last year UCCNC + UC100 USB controller cost me £75, with the parallel card costing £10 - a total of about 115 Euros. To that must be added the dreaded VAT at 20% in UK!!
Total 138 Euros or thereabouts.
Peter
UC100 + UCCNC
- 18 Online
