Fusion 360 now supporting stepcraft with 4th axis
Hey guys
I finally got fusion 360 CAM to produce a post for UCCNC, that performs a cut, then rotates the a axis and performs another cut. It can now do a complete part with pauses for tool change or not as required. Awesome !
This software is extremely powerful, for a free product if you are able to get it. I highly recommend it.!
Great work!! Can you post a video?
I have attached the Post Processor - for Fusion 360 Stepcraft when using UCCNC, with the default Rotation axis, setup to be parallel with the machine's Y axis ( the long axis ).
I have disabled the Home command at the beginning, and the goto Z=0 command at the end.
If you set the x/y/z axis in fusion360CAM to be at a particular spot on the model or stock, then move the tip of the tool to the same spot on the actual stock sitting on the stepcraft machine - zero all, it will cut correctly from there.
You may need to disable softlimits, or manually set the to something meaningful in the axis setup page of UCCNC for x/y/z axis.
- 7,672 Themen
- 4 Online
