UCCNC & Stepcraft 300 problem
I have recently bought the Stepcraft v2 300 with the parallel port adapter and the uc100 motion controller. I'm trying to do my first CNC milling, but I have a problem. Whenever I try to jog the machine to the right on the X-axis, I get an error in UCCNC saying "A machine axis position software limit was reached. This axis was now stopped." I'm using the V2-300 profile from the CD.
On a related note: when I load the included test file ("Stepcraft-Logo.nc"), no matter where I zero the machine, I always get the error: "The current job is out of the set software limits. Adjust the softlimits to fit the job extents or disable the softlimits."
In the configuration tab the softlimits are set to 0 (-) and 207 (+). Altering these does not seem to have any effect.
After installation everything seemed to run fine in a test run, but now I can't figure out how to make it work anymore.
Any help would be greatly appreciated.
Thanks in advance!
René
Just wanted to say that Rory from Stoney CNC helped me out by explaining how to disable the soft limits.
Have you Home'd the machine?
Stepcraft 2 420
500 Watt Spindle
3D Printing System
3d Probe
T-Slot Table
Tooling:
1/8" 60 Deg 4 Flute V Bit
1/8" 4-Flute Square Nose End Mill
1/8" 2 Flute Ball Nose End Mill
1/16" 2 Flute Ball Nose End Mill
UCCNC and VCarve Pro
Total Newbie!
maybe share what you did exactly to remove the limits?
>> config
>> general settings
>> enable soft limits (uncheck box)
>>apply
>>save
>>close and re-open UCCNC to verify the changes have saved.
homing the machine is required in order for the soft limits to work
- 7,667 Themen
