Best CAD/CAM solution for Stepcraft?
![bluskies bluskies](http://stepcraft-systems.com/wp-content/uploads/wpforo/avatars/bluskies_30060.jpg)
Hi :cheer:
I'm new here and I am currently building my SC2 840, waiting for replacement parts.I try to pass time with looking at possible software solutions and have found a few entries on this, mostly in the german section of the forum (my german is not good :blush: ) so I thought I'd start a thread where this could be descussed. All thoughts on the subject are welcome, HW-SW combos that works and ones that dosen't, what kind of interface does one need in the SC to use the different SW solutions etc.
Right now I'm trying to figure out the SW combo to use and if my USB "Full versin" is compatible/usable or if I need a converter, controller, buy the other (Sub 25) board.
Considering these combos:
Solid Works & Solid Cam
Solid Works & HSM Works
AutoCAD & Inventor HSM
Only Inventor HSM
Only Fusion 360
As far as I can see Fusion 360 should be the easiest solution to start with and the most future oriented solution? Is that "plug&play" with the HW I have?
:silly:
![Javier Valencia Rodriguez Javier Valencia Rodriguez](http://stepcraft-systems.com/wp-content/uploads/wpforo/avatars/jvalencia_29638.jpg)
I use this:
CAD: Qcad
CAM: V-Carve/Aspire
It works for me.
Stepcraft 2 840
Kress 800 FME
UCCNC + UC100
V-Carve + QCad
Thanks 🙂
Which machine interface do you use it with?
Is it good at auto creating optimized tool paths or does it require a lot of manual "fiddling" between CAD and milling start?
I use UCCNC, but your software also works with it.
It's very easy to work with.
Stepcraft 2 840
Kress 800 FME
UCCNC + UC100
V-Carve + QCad
Qcad is horryble, you must be having a problem to be able to work with such an ugly piece of software... Even if it is free.
You can see how bad the things done by users using qcad look like!
Use Estlcam combined with any other decent cad software.
I personnaly prefer Autodesk Autocad or Autodesk Inventor Pro or Inkscape(for pictures) and from this softwares I import in estlcam the desired shapes drawings.
In estlcam i can simply choose what tools/depts/speeds and lots of other details...
From estlcam we save cnc program as .din extension.
The .din extension is easy opened under winNc-pc just for production.
Take note:
Take care as in inkscape you have to open a A4 template and ensure that you work in mm and not pixels. After you make this there will be corect dimensions from the first cad-program to the final cutting program.
- 7,517 Themen
- 10 Online
