UCCNC - Getting the most out of it
As said in earlier threads, UCCNC's instructions are not very clear :blink: and I'm sure I'm missing loads of features, so for a starter can anyone shed some light on:
Getting my HF500 controlled
Setting a home/park position (so each time you load the software it remembers these positions)
And finally (for now)
Can I connect this pendant http://www.ebay.co.uk/itm/CNC-4-Axis-USB-Pendant-Manual-remote-Control-JOG-encoder-for-Mach3-ONLY-/252056624563?hash=item3aafbeddb3 to UCCNC, the advert says Mach 3 only
Looking forward to any answers and further questions.
Hal
SC840, HF500, UCNNC, Vcarve Pro, Turbo Cad
Hi again Hal,
I think I can help you out on the spindle control - I have just been throught the excercise on my HF350. I took a screenshot of the best config settings I came up with for relating actual measured spindle no-load speed v G code demand. The results are not very linear, and exposed the fact that my HF350 does not operate below about 6000rpm.
Hope this is of use to you as a starting point, though I doubt if the HF500 has the same chacteristics as the HF350.
Peter
UC100 + UCCNC
Many thanks Peter,
I will give go this afternoon
Hal
If the pendant acts like a keyboard, you can map each key to a function in UCCNC. If it acts like a controller, you can map it to keys with a free software and then map it with UCCNC.
A cheap "pendant" that will work easily would be an external wired or wireless keypad like this:
Stepcraft 2 840
Kress 800 FME
UCCNC + UC100
V-Carve + QCad
Brilliant! I now have control of my spindle - many thanks Peter
Hal,
That's excellent - does your spindle bottom out at around 6000rpm like mine? If it is different, just tweak the min speed parameter to get the best correlation between the S code value and your minimum.
Peter
UC100 + UCCNC
Hi Peter,
Yes it seems to be the same as yours, I had a slight issue of UCCNC turning off the spindle when it moved onto the part of the job. I'm sure this is me not really understanding what is going on with UCCNC but certainly the machine is becoming 'one unit' now.
Hal
- 12 Online
