WinPC-NC USB Not Recognizing Not Starting
I just replace the controller board on the SC600 with a new board and now WinPC-NC does not want to work correctly with the SC600. It tells me it is looking for me to upgrade the software somehow so that I can get full access to all of the features, including the 3rd and 4th axis which no longer are available. I assume it is looking for some changed serial number from the controller board but I am at a loss for where to put it in. Can anybody help?
SC 600. WinPCNC Pro/UNC, 3D Printhead, Aluminum Bed, Foam Cutter, Engraver
hi,
did you change the the complete board within the usb-module ? this module is working like a hardware-dongle for the software!
if you changed it you have to contact stepcraft or the software vendor to get a new winpc-nc version including the correct software serialnuber corresponding to the number on the usp module.
Yes I did change the USB board since a new one came with the control board rather than swap in the old one. Are you saying that if I swap the old one back in my software will function correctly?
Drilldevil,
Thank you very much for the help. I swapped the original usb board back in and WINPCNC is functioning as designed.
Many thanks,
Gary
- 10 Online
