UNCNC Settings for HF350
Hi All
Just bought the HF350 spindle - does anyone have the settings I need for UNCNC so that the spindle is controlled by G Code.
Thanks in advance.
Stepcraft 2 600
HFS 350
UCCNC
Asked the same question, the answer given was that it is not possible at present but coming soon.
Turbocad, VCarve, UCCNC, 420, HF350.
Do you mean UCCNC? If so, I can help (assuming it works the same way as the HF500).
Hi Wolfram - yes I mean UCCNC.
Stepcraft 2 600
HFS 350
UCCNC
This is the UCCNC configuration I'm using.
You need to connect the supplied D connector from the back of the HF spindle controller box to the matching D socket on the back of the Stepcraft.
This config is working for me, but I'm not sure if all the parameters are correct to give you a proper match between the gcode speed parameter and the actual speed of the spindle (this is because, for various reasons, I'm currently testing two HF500s whose controllers have completely different characteristics...)
Hope this helps!
Thanks Wofram - I'll give it a go this evening.
Stepcraft 2 600
HFS 350
UCCNC
- 7,515 Themen
- 10 Online
