Stepcraft profile for UCCNC
Can someone share thier profile for UCCNC software for me to try.
Stepcraft 600 v2 w/UC100 and UCCNC, Dremel, Cut2d, QCAD
Let me rephrase that, configuration profile in UCCNC for StepCraft.
I don't understand why it can't be available to download so we don't have to rely on someone to send it to us.
USA distributor is slow here. 🙁
Thank you Rory!
he emailed me what I needed.
Can you please send me too?
I'm still on 1.1019 and as I read it is not recommended to use the profiles from the old installation to the recent one. I can find UCCNC update, but not with the stepcraft profiles.
Thanks,
JG
I had the same concern when I recently updated from V1.1027 to V1.2xxx, however Rory assured me that there would be no problem in using my V1.1 version.
This proved to be the case, and I simply copied my old V1.1 profile to the correct location in the V1.2 installation - it worked faultlessly. Of course the macros have to be an an appropriately named sub directory as well.
Peter
UC100 + UCCNC
The manual way is:
- copy all macros from the old release folder to the new release folder
- make screen shots of every CONFIGURATION tab in UCCNC
- follow the screenshots and configure all CONFIGURATION tabs in the same way... (parameters, check-boxes,...)
...this was what I did and works!
Hartmut
ESTLCAM & QCAD
DK5LH/G11
Thanks, but it does not seem to work for me. I copied the profiles, started and load the profile. It noted that it will restart and load the screen, but than it says it can not find the screen file. When I copy the screen file also, it does start, but the program window is bad, there is just a few button, big white places 🙁
Regards,
JG
Sounds as though your V1.2 installation is corrupt - I would be tempted to uninstall and then re-install v1.2.. make sure it works correctly using the default profile before attempting to use your Stepcraft one.
Don't forget that the command line for loading your profile must be of the form "C:/UCCNC/UCCNC.exe /p myprofile" (see page 11/70 of the user manual)
Peter
UC100 + UCCNC
Can you share your screen file?
Thanks,
JG
Not quite sure what you are after - do you means the c:UCCNCScreens folder? Obviously something critical is missing.
If the s/w doesn't install correctly, then perhaps the downloaded file is corrupt - download another clean copy and try installing in a different directory. You have the .net framework installed (quote from page 4/70 of the user manual)???
"Prior to install the software the .NET framework 2.0 need to be installed. The .net framework 2.0 is
Microsoft's runtime environment for applications (like the UCCNC) developed in Visual Studio. etc. etc"
Otherwise I don't have a clue!!!!
Peter
UC100 + UCCNC
Hello,
Yes, the screen file in the screen folder.
The stepcraftscreenset.ssf.
I've downloaded the update from here : http://cncdrive.com/UCCNC.html , but it does not include any stepcraft specific thing, nor the screen file what is missing if I copy the stepcraft profiles.
Regards,
JG
Don't really understand how the installation completes with an important file missing. I have attempted to send you a copy of mine, but it may be culled by the forum software - it's quite choosy about what files it will send and their maximum size.
Peter
UC100 + UCCNC
Peter
See the attachment was culled - I'll try again with the file renamed as a .txt file. It is in plain text anyway!! Rename it if it comes through this time
UC100 + UCCNC
Hello,
This might explain the situation. Do you see the Stepcraft tilored version of UCCNC? On the runnign program, on the top right corner, do you have Stepcraft or UCCNC logo?
In the installation I copy from, I had stepcraft logo, the profiles came with the UCCNC install.
Now I updated with the clean version and copied the profiles, but it is missing the screen file and it is not the "defaultscreenset.ssf", it is the "Stepcraftscreenset.ssf" what I'm looking for. If I copy the old one to the new version, the window is like that what I inserted.
Anyway, now I made a screenshot of all settings and copied into the new installation default profile and it seems to work. I did not copy the profile.
Regards
JG
- 7,662 Themen
