UCCNC and Fusion 360
I don't suppose that anyone else has tried this combination?
The CAM module in Fusion 360 comes with a number of post processors for generating code. There isn't a specific one for UCCNC. The best luck I've had soo far is with the WinCNC post processor, which has worked well for peck drilling (won't do straight through drilling) and 2D contours with tabs soo far. I have to do each operation seperately to get the best, most consistent results.
The user manual for UCCNC suggests that the software can interpret RS-274 compliant code. There is an RS-274D post processor, so I would have thought that this would be the best post to use, however the code as interpreted by UCCNC does not detect arcs, so my nice radiused parts are shown as square edge parts. There is also a problem with the placement of some holes.
Rory, are you able to comment on UCCNCs exact use of RS-274? The post processor in Fusion is for RS-274D.
By the way, I would very much like UCCNC and Fusion 360 to be my standard toolchain. Fusion 360 represents fantastic value for money considering the cost of other autodesk products like inventor (not an autodesk employee!!)
Thanks,
coanda
Yes - try the Mach3 post processor?
Fusion is indeed excellent!
We will get more details on this when time permits.
Rory
I had tried the mach 3 post. I will try it again later today, in case changes I made to the operations afterwards made the model more optimised for the mach 3 post.
Autodesk forums seem very open to additions and changes to post processor sheets, so as soon as we understand what we need to give UCCNC we can submit to autodesk and get a specific post for UCCNC.
Mach3 post p from Vectric works with UCCNC directly. So if there is a Mach3 post - it should work.
Okeydokey,
I took some time to compare the paths produced by 3 likely post candidates. WinCNC, Mach3, RS-274D.
Here are a couple of images - they show the top-down and iso views of how UCCNC interprets the G-Code in each of the files. All files are produced by Fusion 360 Mac version 2.0.1457.
Top-down Image
Iso-View Image
WinCNC post produces an accurate representation of the part, and the RS-274D and Mach 3 Posts do not. There are differences in how the traverse paths have been calculated, as well as the shape of the parts - no arcs and they seems to truncate the widths of the parts.
I am using Fusion360 and mach3 post for mach3 and had no problem so far. It is generating also arc's.
Did you compare the g-code?
By the way, you can write your own post processor by changing another one (I did that when I still had WinCNC because I disliked some settings).
p.s.: The reason why I have choosen Mach3 and not UCCNC was that I could not test UCCNC in real life on maschine without buying license.
Frank
Absaugung und Vakuumtisch
I downloaded Mach 3, and I see there is a plugin for the UC100. The program ran in demo mode just fine on my win7 64bit desktop. Will try it on the laptop tomorrow afternoon.
I can confirm that the Mach 3 post processor works with Mach 3 just fine (good news!)
There are differences in the G-codes produced by the Mach 3 and WinCNC posts. The following sections show the g-code for the same drilling operation for the Mach 3 version and the WinCNC version. I note that whilst the coordinates are the same between versions (true for both drilling operations for this component) the way the posts use G-codes etc isn't.
MACH 3
(DRILL4) S5305 M3 M9 G0 X-21.235 Y10.525 Z6. G73 X-21.235 Y10.525 Z-3. R5. Q0.6 F796. X-21.15 Y27.525 X-9.225 X13.765 Y10.525 X13.85 Y27.525 X25.775 Y-27.475 X13.85 X13.765 Y-44.475 X-9.225 Y-27.475 X-21.15 X-21.235 Y-44.475 G80 Z6. G28 G91 Z0. G90
WinCNC
[Drill4] S5305 M3 X-21.235 Y10.525 Z6. G73 X-21.235 Y10.525 Z-3. R5. Q0.6 F795.8 X-21.15 Y27.525 X-9.225 X13.765 Y10.525 X13.85 Y27.525 X25.775 Y-27.475 X13.85 X13.765 Y-44.475 X-9.225 Y-27.475 X-21.15 X-21.235 Y-44.475 G80 Z6. G53
And UCCNC much prefers the WinCNC version.
Oh, Mach 3 is also quite happy running the RS-274D version, but not the WinCNC version because it uses square brackets and outputs G22 in my case which is not understood.
Looks like WinCNC post it is!
Hi Guys 🙂
I'm quite new with my SC600 V2 but not to cnc machining. I'm working with fusion 360 to do my first cut !
But I have always the same problem when I click on Cycle start in UCCNC : The current job workspace is out of the set software limits.
And if I look at the Iso view in UCCNC the volume/red line (not the cut itself) seems huge compare to what my stock/workpiece is on Fusion 360 (see img attached)...
I don't how to fix that ... I've already try a lot of settings in fusion 360.
Any suggestions are Welcome ! thx for your help.
Julien 🙂
Another screenshot with a different model. I've try few postpross (winpc, mach2/3 Etc...) :S . Nothing changed and can't find anything suspicious in the G-code file.
Can you send us the Gcode file ?
Done by Email Rory. Waiting for your returns :). I will share the issue when everything will be fixed.
Thanks for your work Rory !
I started using Fusion 360 CAM, to check how it works, but I always have erros (arc errors) when I load the file in UCCNC. With Cambam (my other CAM software) when I export to g-code (Match3 settings) to UCCNC works very well, but in fusion 360 when i export to g-code (match3 settings) I always get same errors, and in the preview screen of UCCNC doesn´t look very nice....
Anyone has achieve export to Fusion 360 to UCCNC without issues??
Thanks,
Stepcraft 840 + CCNC
Kress 1050 and in a near future with SuperPID
Hey guys,
I am having exactly the same problem trying to do a 3d profile around bored holes.
Has anyone had any success with Fusion mach3 and the UCCNC software?
We need to find a solution, because fusion cam is awesome !
Here is my request post on the Autocad CAM post request page.
Someone has posted a UCCNC post processor to try with fusion 360 to see if it works better.
here is the link to the file / post
https://camforum.autodesk.com/index.php?topic=8254.0
I´m going to test it.....
Thanks...
- 7,515 Themen
- 4 Online
