the ring of power
Hi.
(mach3 and stepcraft 420)
Here is my project. The ring of power (Loard of the rings)
first i drawed the shape in Aspire. (here is the difficult part:( )
then i engraved it on an acrylic board (mach3 and stepcraft 420)
and then i lighted it up with a blue high power led with 2 batteries AAA size and
a tiny switch.
and that's all.
this is really cool, i am looking for the elf writing, but i did not find anything,
Is it possible to send or post the dxf.
regards georg.
Excellent work! Thanks for sharing.
MfG
Roy
Cool thing,
Thank you for this nice inspiration.
@ angel_xt the same idea i´ve had 2 weeks befor. But i try to start milling with wood. It comes later. Did you use Aspire as trial-version or full-installation?
@Georg Surch in the net for FONTS and there you will find some differend kinds of this letters. If i find the link, i´ll send you later.
Greatings from germany
Frank
hi
thank you
I use the full Aspire version
hi
Ok i will send you the dxf file or gcode if you prefer.
just give me your email account
you have to use a 30 degree 0.1mm engraving tool
the working depth must be at -0.1mm (Z axis) at a speed of 20mm/sec
take care of acrylic melting because of temperature
Nice job! Could you give us the details which milling bit and speed you used for this job?
Stepcraft 840/2
UCcnc 100
Parallel port
Kress FME-Q 800w - Dremel 300
Aspire 8.5 software
From Belgium
supplier : Sorotec Germany
- 7,660 Themen
- 91 Online
