Systainer for Scheppach PL45
Since my stepcraft is willingly to cooperate, i wanted to make systainers in poplar plywood, because of the lighter weight.
I created a logo 'Valery's Garage' in photoshop, converted it into an eps and imported it into aspire and combined a 1mm bit with a 3 mm clearance tool.
The logo seemed to be a little too small for the 1 mm endbit, but for the first time i combined two toolpaths in one job... so i'm happy with the result.
Stepcraft 840/2
UCcnc 100
Parallel port
Kress FME-Q 800w - Dremel 300
Aspire 8.5 software
From Belgium
supplier : Sorotec Germany
Nice effort 🙂
But I see you have a multiplex adapter ring made for your Dremel. If you like to made some precision projects in the future I suggest you buy the proper adapter ring from Stepcraft. That one is more sustainable and more accurate.
A tip.
Milling in beech plywood gives a rough edge when using a 2 flute or 1 flute mill. Use a diamond shape endmill for the final cut this will give a smoother edge.
But nice work.
greatings
i know, but since i have been struggling so much with the stepcraft assembly, i refused to invest any more money and that Dremel setup wasn't meant to last... just checking if the thing would work with a lighter endmill than the more pricey and much heavier Kress 800 endmill...
Now i know the thing works, i will most certainly buy the proper adapter for the Dremel 300... only i don't know which Dremel adapter i should pick: the 18 or 19 mm... is there somewhere documentation to be found which Dremels go in which Adapter?
So i should beter use a 45° carving tool to finish up my beech plywood projects? Or could you give me a link to the specific endmill you're proposing?
Stepcraft 840/2
UCcnc 100
Parallel port
Aspire 8.5 software
From Belgium
vdh43,
If you want a small spindle for "light" milling I suggest to buy the Proxxon IBS/E this cost around € 75,00 and is much more quiet than a dremel.
I have my 420/1 upgraded with the higher gantries and the 420/2 toolholder.
On my system I have now a Kress 1050 FME/P with ER16 collets.
This has one disadvantage the dust adapter does no longer fit so I have to create a new one.
Why I choose the 1050 fme just for the lower rpm possibilities especially for alu or plexi materials.
The endmills I usually buy at sorotec.de they have a wide range of bits. ( https://www.sorotec.de/shop/Zerspanungswerkzeuge/sorotec-werkzeuge/1-8-werkzeuge/3-175----1-8---Fraeser/ )
And if you want to try out some projects on aliexpress you find chines ones who are really cheap, but last not so long.
To make smooth edges this is a way to do it.
Make your toolpaths as usual so for pocket a larger clearance tool and smallest for fine edge. Now make a third toolpath with the quick engrave button. this will mill on the line and now use a 45 or 60 degr. V-bit with the same cutting depth as the pocket. Now you have a nice chamfer.
Save all toolpaths to one file and load up.
- 7,436 Themen
- 5 Online
