Filliers Dry Gin 28 logo
My first attempt with V-carving : a logo of my favorite gin : Filliers Dry Gin 28... imho : a nice, stylish logo, carved in mdf 3,4mm hardboard with white coating...
Very long job, due to the low speed of my settings (due to an imperfect assembly of my stepcraft), but thankfully, i discoverd the 'run from here' setting in my uccnc, so i can spread a job over several evenings...
Executed with a 1.5mm 45° v carving bit...
Now i understand the sense of a bigger clearance bit....
Stepcraft 840/2
UCcnc 100
Parallel port
Kress FME-Q 800w - Dremel 300
Aspire 8.5 software
From Belgium
supplier : Sorotec Germany
nice job !
![Doug Doug](http://stepcraft-systems.com/wp-content/uploads/wpforo/avatars/Doug_33359.jpg)
That looks beautiful. Very nice. How long did it take?
about 4 hours, due to the low velocity my configuration is working at.
Stepcraft 840/2
UCcnc 100
Parallel port
Aspire 8.5 software
From Belgium
Welk materiaal heb je genomen?
Rüdiger
wit gelakte MDF hardboard van 3 mm (standaard te koop in Hubo / Gamma)
Stepcraft 840/2
UCcnc 100
Parallel port
Aspire 8.5 software
From Belgium
- 7,511 Themen
- 6 Online
