Tool tray
![Javier Valencia Rodriguez Javier Valencia Rodriguez](http://stepcraft-systems.com/wp-content/uploads/wpforo/avatars/jvalencia_29638.jpg)
I saw this post in the forum about a tool tray for the steppy and wanted to share mine.
I followed the procedure and the result is great. Thanks Hoedur for sharing it.
Stepcraft 2 840
Kress 800 FME
UCCNC + UC100
V-Carve + QCad
I'm glad you liked the idea!
Also your version is great! :woohoo: :woohoo: :woohoo: :woohoo:
Rüdiger
Wow! good job!
One question:
Is this material melamine?
If yes, which tool did you use in order to have this clean cut?
Thanks,
Javier
Wow! good job!
One question:
If yes, which tool did you use in order to have this clean cut?Thanks,
Javier
It's 16mm white MDF. Very cheap.
I used a normal 2 flute 6mm upcut wood endmill from CMtools.
Stepcraft 2 840
Kress 800 FME
UCCNC + UC100
V-Carve + QCad
- 7,660 Themen
- 62 Online
