showercurtainrodholder
Just got my 420 so wanted to start with something easy. My shower curtain rod holders were from the late 1970s and needed replacing. So made new ones from 6mm MDF. Will probably paint them or replace the MDF with Acrylic so that they stand the humidity better. But for now they will do fine as they are. I designed them and used the CAM in Fusion 360. Only problem I had was that UCCNC complained the the work area soft limits would be exceeded (even though they clearly would not). I traced this to some strange "home" location that somehow got included in the post. Need to look into that some further but got it working by removing G28 directly in the code as suggested in some other post.
Parts in Fusion 360:
Cut out parts:
Before:
After:
I had the same problem (am a new user).
I think your soft limits problem is probably because you had not gone to 'Home All', before you start, when first turned on, after clicking reset simply check all movements working, Then press 'home all' the unit should go to the top left corner (back of unit) as looking from tthe front with stop button, the system then has the correct start point, for the limits.
To make the soft limits work correctly you must be using the correct profile for your machine, not the general profile.
Have read in forum several people saying they turn off soft limits, I leave it on and have no problems, except the 'Z' axis stops a bit high above the table, but prefer this to it going too low.
Hope I am on the right track, as I say, am a new user.
Alan
SC600/2, Kress 1050, UCCNC with UC100, Cut2D Pro, TurboCAD and Fusion 360
hi,
one hint: the material mdf is not resistant for water or steam.
Thanks. I did home the machine and I am already using the correct profile. Most likely the culprit is some setting in Fusion 360 that I have missed or not understood. I'll look into it more during the next project but it's not a major problem as the code is easily removed before running the machine.
hi,
I'm fully aware of that and as I already wrote I will either paint them or replace the MDF with Acrylic.
oh, ok. i didn't get this part ^^.
in my opinion and if you have the choice you should better use makrolon(polycarbonat) instead of arcrylic glass (pmma)
- this is more stress and shock resistant (you need this property at this point where you fix the part on the wall with a srew)
- more flexible
- 9 Online
