Wall clock
great work! :woohoo:
Rüdiger
Very beautiful. Some day i will do something like that. I'm still a newbie in CNC world 🙂
Stepcraft 2 430
Kress 800 FME
UCCNC + UC100
Cut2D Desktop
What end mills did you use?
Stepcraft 2 840
Kress 800 FME
UCCNC + UC100
V-Carve + QCad
wow!!!
Estupendo!!
It looks nice, but I think, that there is a great failure. In every of the 12sectors, you have 5 points. That are 60 points. You also have deviders (lines) between the sectors. That are 12 lines additional to the 60 points. The space between the points is the same as the space between the points and the lines. So you have 72 markers and 72 spaces for 60 minutes.
Normaly a clock has 12 lines for the hours and 4 minute-markers between each pair of lines, totally 48 minute-markers and 12 lines.
I hope you understand what i mean.
If only the points should be minutre-markers, the space between the two points with the line between is too great. Its more than the double space´as between two points without the deviding line.
Ralf
Vakuumtisch: VT3040 CNC-Plus
This is New Age
Especially designed for bosses and there employees,so they don't know that they are working longer:)
- 7,369 Themen
- 63.3 K Beiträge
- 35 Online
