Vectric Aspire Question
Hi everyone!!!!
Its any way for vectric aspire to automatic calculate the rigth tool diameter for pocketing, for example a letters?
i select the smaller diameter tool because if not in the simulation are some parts that dont be milled, but the working time goes so high.
Thanks in advance
The
First of all welcome.
Second the answer is no. Aspire will however calculate the toolpaths for two diameter mills in the pocket function.
Select the largest diameter you will use and the smallest you need for the sharp corners. Now let Aspire calculate, you get two toolpaths one is clearance and the second is clearance 1. That will do the job.
Third in the future give as much informormation about your hard- and software as you can that will prevent us from quesing.
- 7,518 Themen
- 10 Online
