V bit question
3 Beiträge
2 Benutzer
3,192 Ansichten
(@mihael)
Hello all.
I’m new to cnc and recently got D600.
So I tried using 30deg V bit on hard wood and it is cutting great but one issue is that fine dust/chips get clogged inside grooves that it cut. After machine work is done I have to remove this with needle.
Is that normal or I’m doing something wrong with cam settings?
Bit is similar to this one https://shop.stepcraft-systems.com/V-Router-partial-halved
Veröffentlicht : 28/03/2021 10:53 am
(@cncmiller)
Reputable Member
Mihael,
most important point is to get rid of the chips. Do this by vacuum dust suction or air blast during the milling process.
There are several solutions on the forum and some how to do plans else go search on Thingiverse you will find a lot of Dust suction shoes or air blast ideas.
good luck.
Veröffentlicht : 29/03/2021 10:03 am
(@mihael)
Ok, seems the issue is that I had not vacuumed constantly but every ~15sec (doing it manually...). Thanks for the tip.
Veröffentlicht : 29/03/2021 1:07 pm
