milling aluminium
Hello,
i own a cnc stepcraft black edition for a few month now and i want to mill aluminium for the first time. i read a lot on the internet but i'm not sure how to do it.
i want to mill with a 1mm 2 cutter end mill. the material is 2mm. what for feeds and speed do you recommend? lubricate is this required?
i hope you can give me some tips.
thanks in advanced for the tips
stepcraft 600 black edition
hf500 spindel
vcarve dektop
winpc-nc
sketch-up
Brics-cad
Harm,
Brave to start with the most difficult material.
Aluminium has many different types Alloys so if you want to mill try to get some of the NEN 5000 or 6000 series.
If you get your aluminium from the hardware store it is mostly soft alu of the 1000 series, this is very hard to mill.
But regardless what you use make sure to take the following in account:
- slow speed of the mill (8.000 - 12.000 rpm)
- slow to medium feed (100 - 150 mm/min)
- don't go deeper than 0.2 till 0.4 mm per turn to be save for the first time go 0.1 per turn
- use a 2 flute millbit for Alu
- good clearance of chips (airblower or brush)
- good cooling (spirit or cooling liquid) apply by airbrush or pipet
- be alert of nasty sounds, hand at emergency stop
Be gentle and you will succeed
I did quite a lot of testing with 6000 aluminium on a Stepcraft 600/2 with a Stoneycnc Industrial quality small HF spindle.
Here are some of my results.
I found higher spindle rpm with a single flute bit worked better.
pd = pass depth
ss = spindle speed
fr = feed rate
pr = plunge rate.
pd 0.2 mm
ss 15000 rpm
fr 10 mm/sec
pr 3 mm/sec
very low vibration, clean cut, oil
pd 0.4 mm
ss 18000 rpm
fr 5 mm/sec
pr 3 mm/sec
pd 0.4 mm
ss 18000 rpm
fr 5 mm/sec
pr 3 mm/sec
very low vibration, clean cut, washing-up liquid
pd 0.5 mm
ss 18000 rpm
fr 5 mm/sec
pr 3 mm/sec
pd 0.7 mm
ss 18000 rpm
fr 4 mm/sec
pr 3 mm/sec
pd 1 mm
ss 18000 rpm
fr 3 mm/sec
pr 2 mm/sec
pd 1 mm
ss 20000 rpm
fr 3.5 mm/sec
pr 2 mm/sec
pd 1 mm
ss 20000 rpm
fr 3.5 mm/sec
pr 3 mm/sec
low vibration, clean cut, no lube
I haven’t listed all my results but hopefully these should give you some idea.
Thank all for the input i'm going to try it and let you know what the result is like.
hf500 spindel
vcarve dektop
winpc-nc
sketch-up
Brics-cad
- 7,518 Themen
- 12 Online
