MILLING CONTOUR LEAD-IN PROBLEMS
HI,
I have lots of problems and gripes every time I try to use 2-d milling. I avoid it whenever possible because of these problems.Unfortunately, not every job can be cut with 3-d toolpaths.When I am forced into using the 2-d paths, one thing that really bothers me is the lead-in / lead-out section.
I often find myself trying to contour around tiny details that require very small lead-ins to avoid gouging the part.Whenever I do this I find myself wondering a couple things...
1. Why is TS Cam not smart enough to avoid gouging the part in 2-d milling ops ?
2. Why is the lead-in required to be so long ? It seems like the radius of the tool is the minimum allowed lead-in. What I really need is the ability to specify something like a .002 perpindicular lead-in on my contours.(just enough to turn on compensation)
Have I missed something or is TS Cam deficient in this function ?
Please help.
I did not find the right solution from the internet.
References:-
http://forum.topsolid.com/viewtopic.php?t=187
Business video marketing agency
Thanks
hi,
sorry but the crystal balls are just out of order ....
you don' t give us any information about used bits, cutting parameters, machined material, used cnc-software, machine,....
no pictures, no cnc-code( gcode).
- 7,660 Themen
- 109 Online
