StoneyCNC VFD Spindel and Auto Tool Changer
Has anyone that own the VFD spindle tried to install an ATC system?
Will the one sold to fit the Kress (same head diameter of 43) mount to the Industrial Quality spindle?
Is that spindle available to buyers in the US?
Thanks!
Chris
I cannot help answer this but would certainly like to know if it would work. That would be the ultimate setup for a stepcraft system.
Ollie
Hello,
I own a VFD spindle and I’m very impressed with its performance.
I haven’t owned either the Kress or Stepcraft spindle so I can’t give you a comparison.
Before I bought the VFD I asked Rory about using an ATC with it, here’s his reply.
"It’s not really a runner to just bolt an ATC module to a spindle. A spindle spinning at 24000rpm is very sensitive to runout. As soon as you have two parts machined separately coming together you run into issues long term with bearings. It’s much better to grind out the cone of the collet when its integral in the spindle design. Otherwise you have tolerance stack up. We only build manually changed collet spindles. Or automatically changed collet spindles".
Changing the collets/mills manually is a bit of a pain but I can live with it.
- 7,667 Themen
