Extended length of roughing toolpast with 3mm EM
Milling
1
Beiträge
1
Benutzer
0
Likes
3,216
Ansichten
I'm a relatively new user, and am practicing milling double-sided, with a work area of 240 x 200 mm. Each side has two toolpaths, one "rough" with a 3mm EM, the other a finishing cut with a 2mm EM. I'm generating the toolpaths with VCarve Pro, to "Mach 2/3 Arcs (mm) .txt", then running these sequentially on an 840/2. The 3mm EM is configured with 4.1mm pass-depth, 0.6mm stepover, 1800mm/sec federate, as per attached screenshot.
Here's the problem:
Vectric Pro times the roughing pass at circa 35 minutes, at a feedrate of 1500mm/sec, but the elapsed actual time for the 3 passes is nearer 6 hours! For the life of me I can't spot the error in the job-set-up. Any help in running this problem to earth would be most welcome.
Veröffentlicht : 28/08/2017 12:39 am
Forum Information
- 8 Online
Unser neuestes Mitglied: Richardreild
Forum Icons:
Themen-Icons:
Unbeantwortet
Beantwortet
Aktiv
Heiß
Oben angepinnt
Nicht genehmigt
Gelöst
Privat
Geschlossen
