Wooden Glasses Frames and Arms
![MACHINE CRAFTED MACHINE CRAFTED](http://stepcraft-systems.com/wp-content/uploads/wpforo/avatars/Mr.%20B_27499.png)
Project: Wooden Glasses Frames and Arms
Materials: 3 mm Plywood and Iron on Walnut Veneer
Stepcraft 420
Proxxon IBS/E spindle
3mm two fluted slot drill
10,000 rpm
300 mm/min feed
100 mm/min plunge
Cut depth 1 mm
Still need to add the hinges and maybe varnish, will post up in the Show your creations section once finished.
Stepcraft 420 (version 1) - HXKJ-GS52-400W Air cooled DC spindle - 445nm Blue Laser diode G2
Geile 'Gewindeplatte'!
Hast das Holz einseitig gebeizt oder war es zweifärbig?
Egal, schöne Arbeit!
Frank
Absaugung und Vakuumtisch
Cheers frankjoke,
Yes that aluminium plate was drilled and tapped M6 using a Bridgeport.
The walnut veneer is just on the front facing side.
Thanks for the answers and sorry that I asked in German!
Was looking for other woods (not standard plywood) to mix in some work as well.
Frank
No problem, Google translate works.
@blanthegenius
Looks crazy cool! :woohoo:
How do you make the hinges and what kind of glass do you use?
Hey Blan
you are definitely on the right side of the street 🙂
How about glasses from a welding helmet?
Be prepared for the next solar eclipse :cheer:
TX for inspirations...
@blanthegenius
Looks crazy cool! :woohoo:How do you make the hinges and what kind of glass do you use?
Cheers speedo,
Have been looking on eBay for glasses hinges Hinges or could make my own not too sure just yet and the glass are from a previous pair of prescription glasses I have, just had my eyes tested and the prescription didnt change.
Hey Blan
Nice idea
Nice idea but that doesn't works for a long time. :blush:
I would check out the Internet for replacement or repair hinges ...
... or maybe just look in your drawer for an old pair of glasses ... :whistle:
Cheers Worldhusky,
I looked at a few types of hinges online, then saw some plastic and decided to have a crack at making my own.
Yeah they may not last that long as you say but I'll give them a go.
hello genius
please no plastics!
how about leather :S
Yes leather would go well cheers.
Was looking to roll twine over the plastic hinges.
Really cool idea. The next solar eclipse can come!
😉 😉 😉 😉 😉 B) B) B) B) B)
Rüdiger
- 7,516 Themen
- 11 Online
