WinPC-NC
![Patricio Francisco González Patricio Francisco González](http://stepcraft-systems.com/wp-content/uploads/wpforo/avatars/Patricio%20Fco._34953.jpg)
My name is Patricio, I live in Santiago de Chile.
My model is 600/2, I use WinPC-NC 2.50 and to design I use Aspire 9.0
Problem: When I open the design in WinPC-NC the machine is not located in the X, Y coordinates assigned
I have removed and installed the software of both programs twice, but the problem persists.
I did not have that problem before. What I can do?
Me llamo Patricio, vivo en Santiago de Chile.
Mi modelo es el 600/2, uso WinPC-NC 2.50 y para diseñar utilizo Aspire 9.0
Problema: Cuando abro el diseño en WinPC-NC la máquina no se ubica en las cordenadas X,Y asignadas
He eliminado e instalado en dos ocasiones el software de ambos programas, pero el problema persiste.
Antes no tenía ese problema. Qué puedo hacer?
Hi Patricio,
not sure if I understood your issue correcly, but if it is a Problem that your xy Zero Point is not set to where it is set in the drawing, please check the following in WinPCNC.
- Go to menu " Parameters "
- open the tab "misc. Parameters"
- set the Option "Zero Point in file" to "orign of coordinates".
I think by default it is set do "Botton left"
Cheers,
Marco
Gelernt auf Stepcraft 420
- 7,517 Themen
- 8 Online
