v2 840
The frustrating thing is that all the parts are surely in separate bins at Stepcraft - and presumably someone goes to each bin and picks up the required number only to put them all in the same bag!! Clever!!
Didn't you number your plastic drawers with the blue background numbers - worth doing before you start.
If your wooden base board is a tight fit, don't use a 7lb "persuader" to fit it as some have done, just ease the fit little at a time by sanding (the baseboard) in the appropriate places. It's essential the base frame is not distorted either. You could check the fit of the Y-axis extrusions early on to anticipate possible tightness in the slots.
Peter
UC100 + UCCNC
- 7,515 Themen
- 13 Online
